B
bardo
Guest
The only part about this I haven't done is designing the frame. I have worked on the suspension that I'm going to use for years same thing with the engine. I had a similar setup in a 88 dodge Daytona go 13.5 8 the 1/4 and that was a much heavier set up also was fwd so I do have a idea of how fast this will be but also know it comes do to me using common sense as when to lift. If no one wants to give me the info because they are worried I'll kill myself or they don't want to be responsible for the outcome that's fine but don't come up with bad reason of "you need a thought out plan" or " it will cost to much" cause to tell you the truth that's a waste of a post. The only thing I asked for was what metal to use. I have a idea but just wanted to make sure. I'm 75% I know what the framework will look like. What other info would the diy go kart gods require to fulfill my request?
