Yerf Dof 3203 Bearing and brake question.
danielzink
Ordered new brakes and bearings from BMI last week.
I used the actual part numbers from the Yerf Dog part number list: http://www.yerf-dog.com/manuals/3203A_T.pdf
The new bearings I got have a "nub" on them....
Not sure if I should just sand/file it down or what.....the stock bearings certainly didn't have this..
And I also ordered a new drum and band as per the part number list.
I didn't pay attention to the description (my fault) but I clearly had a 4" brake before...
Along with the order I got a new swingarm
It looks like there's a provision for the new brake band....I'm just having a hard time wrapping my mind around how the band is going to center on the drum and axle..
Thanks for looking.
Dan
danssoslow
Louisville, KY
It looks like a 6"band. Could you not simply buy a 6"drum? I wouldn't go wacking off pieces on your bearing. There shouldn't be a reason to do so. It appears to be a run of the mill axle bearing. Every axle bearing I've ever ordered had that extra bit on the inner race.
Bearings: That nub is a locator for use with pillow blocks or cast flanges, they shouldn't give you any trouble with pressed flanges...
Swingarm: Wow, that looks a bit different...
Brake band: Once you fasten the other end, it should centre itself fine...
My bad - I also got the new 6" drum....
It just doesn't look like its all going to fit...
Now that could be a problem...
danielzink
Problem is the nub interferes with the stock flange mating up to the outside of the bearing.
Would you/I assume that the extra "tab" on the new swingarm is for the other end of the brake band ?
Thanks !
danssoslow
Louisville, KY
Wow, I totaly missed what you were trying to show in that pic. I thought you were complaining about the larger width on the inner race. Stike my last comments. Pop that pimple! Is it a roll pin, or something that can be easily pulled?
danielzink
Check the pic below, the arrow shows the mounting position for the band
Yep - thanks.
That's kind of what I was trying to say in my previous post.
Now to figure out how to get that locating pin out of my bearings....
:surrender:
It shouldnt matter that much at all. There is space between the two halves of the "bearing cups".
If it is a prob, just touch the bearing to the grinder, its not like this is going into a cast housing where it needs a perfect finish.
