dcastillo
So in another post I have a picture of my setup with the electric motor motor really far back on the kart. I had issues with throwing the chain (and per recommendation) I moved it a little closer which has helped.
my current mounting system is very temporary, thus also causing the motor to shift a little while riding and throwing the chain.
I am ready to weld a more permanent solution now but want to put it in the best location.
So what do you guys recommend? keep it behind the drive wheel (and as close as possible) or should I modify the frame/chassis and mount it directly over the drive wheel?
pros/cons?
thanx again for all the great help
heres the first family ride on it
http://youtu.be/wqsR2ezy3RU
pros/cons?
