new pro kart picked up last night
zip kart
ireland
wel lads
just picked this kart up last night
it is a biz kart
with 2 genuine Honda gx160's on it
brakes need new pads but still work good
both engines start 1st pull
and the only thing is when I start dem up it slowly moves off itself ??
is that just because of the idle being too high ???
here's some pics more 2 come
firemanjim
Just kartin' around....
Houston Texas
Maybe slightly high idle, but remember., you got 2 motors so the resistance to roll at idle got cut in half....
zip kart
ireland
1 of the engines is idling abit higher dan d other because I started 1 on its own
then turned that off and started the other which was idling higher
so im guessing lower the idle speed
im not sure which screw is the idle
theres 1 that's black and plastic
maybe a picture will help me ?
zip kart
ireland
sorted out the idle with both engines
are the clutch apposed to be making noise when kart is idling?
This may be a stupid question-don't have a lot of kart knowledge, but the last kart you looked at was direct drive. What kind of clutch system does this one have?
zip kart
ireland
ye I was getting the other kart but the guy sold it
let me down big time
this kart has centrifugal clutch's
NOW it really looks a stupid question but the OP posted that last post while I was working on mine. That's where I was heading though, could be bad clutches (or maybe dirty/rusty and need to run a bit).
zip kart
ireland
how can I clean dem without taking them off
maybe the bushings on the clutches need to be oiled up?
the exact same?
One carb manifold for both with both carbs on it. (bwww.. you don't want to do that ;))
A tachometer to read the EXACT rpm of one engine and "copy" that to the other
zip kart
ireland
As good as i can get them
as i dont want 1 engines clutch engaging before the other and 1 pulling the other
where wud i get a tacometer
is there anymore solutions
Russ2251
AZUSA:Powered by LAWN-BOY
A tach is not necessary. As long as both carbs actuate at close to the same time you'll be fine.
I synchronized mine visually and runs like a Swiss watch.
Just check at fully closed...1/2 open...and then full open.
Metalbender
I sync the throttle bodies on my bike with vacuum gauges...set them right with no guess work...you can get a set of gauges from ebay for around $50...they will also work on 2 separate carbs on different motors...
