Will go kart steering idea work
BigThieme
This is a picture of my steering I dea so the tire can move and the steel is 1 cm thick and the opposite side of the tire is going to be bolted and welded on
dmax
mich
Might be hard to get all your angles right but it should steer, I'd use lots of lube or a bearing to help it swivel
Metalbender
I'd also round the ends where it comes together...square edges tend to bind up...and make sure there's clearance for the two pieces to pass freely...probably wouldn't be a bad idea to put a nylon spacer or washer between them where they bolt together as well...metal on metal tends to lock up...not a good thing when it comes to steering...just my worthless opinion...
BigThieme
Yes I will be putting washers between the two pieces of metal I wash going to use metal washers but your right it would probably be better to use nylon and thanks for your idea
I'm sorry assuming the bolts are 90° through the plates that will NEVER turn with offset bolts.
IF you manage to place the two bolts at the very same angle at the very same pivot,
where's the point in not using one bolt? just like in a regular setup?
BigThieme
I guess I could do that it would be easier oh and why do u have a wired face for your profile picture
Cute isn't he...
It's an image from an advertising (cookies of some sort)
it was written
"I wanted cookies, and all I got was aunties kisses..."
(loosely translated)
I had to laugh real hard, and eight minutes later it was scanned to my computer being my new avatar (that was four years ago or something)
OK
So you basically want to steer a kart like a tank. Lot of talk about re-inventing the wheel here. I don't mean to dis you in any way, but wouldn't it be easier just to get use 2 brakes (band, disc, scrub, feet...) and if you live through that THEN re-design how to stop a rotating wheel?
JMHO x2 ...
BigThieme
OK
JMHO x2 ...
It's going to attach to the frame and this is a design for the steering so the wheel can move
Cute isn't he...
it was written
BS-THAT'S HIM...Taken right after reading one of my posts...EVERYBODY loves Douggy.:rolleyes:
well because this:
is the same as this:
it will not pivot.
This instead:
has technically ONE pivot hole, and would turn if the sheets wouldn't lock (but they will)
Also you'll run into problems with the angled bolt...
Just forget about it and use something like this:
this can be mounted in an angle (should be mounted in an angle ;))
