honda clone clone build-20hp
Thats just nuts, an easy +200kmh in the straights......
However this is not a clone engine, it has a transmission, 2 stroke 250cc water cooled, hydraulic clutch....
basically all but what were talking here....
firemanjim
Just kartin' around....
Houston Texas
:iagree::lolgoku: This guy is just being hard headed..... He KNOWS what he's talking about, and isn't gonna listen. Just like the oil cooler thread. Let him do it his way and "help" him along the way. When it all fails and he eats his pride, he will be humble and actually listen to the advice given next time. Let him throw all his money at it just to figure out it wont work,he wont be happy with performance, and he needs a bike/quad motor to go that fast... :cool:
J_Walker
Florida
OP; I have a honda NSR500 engine, I'm going to put it in my gokart, and my target top speed is 170-200MPH. should I use just pressure treated ply wood? Or marine grade plywood for my engine mounting brackets? Also I got 2 wheel barrel tires, and a set of HF tires, with some bearings I got a homedepot. what size sprocket would I need?
I shall call it, my Pallet Gokart!
machinist@large
West Michigan, 49331
Maybe so... But what's the question?
I think it's in here somewhere.....
fowler
Bullsbrook West Aus
I just don't think this dude understands the differance between a clone and a sports bike
He's read the wiki artical on engines and internal combustion
And as far as he can see a clone and a sports bike work just the same
Just forgetting the small details that make the differance
I honestly don't care if u build this and I will help where I can
But some of the questions can't be answered
Lets face it if it does work it'll be great to see
If it doesn't then hopefully it ends up on YouTube and we al get a good laugh
Just hope he doesn't end up dead
Monkeys1990
texas
i undestand that a sport bike has more gear that a clone i understand all that, but ive also seen clones that goes up to 60-100mph at tracks and i also seen people use tranmisson coolers and had there clones drop in heat by ike 2-6 degees...but im going to be nice and go a whole diffenet way with this that you guys might feel better aboput and be able to help me on.
lukasdlf
Lima,Peru
I think the point here is that the guy wants to build or modify things himself, he just doesn't want to put pieces together like a puzzle.
My advice and I think many will agree with this option (that is actually which everyone gave).
Sell ​​the engine you have, look for a small motorcycle engine (preferably a Japanese one) so you have to do modifications to achieve the mph you want. The challenge would still be the same, but more reasonable and I think it's more remarkable modifying a motorcycle engine one than an honda clone due its complexity.
My native language is Spanish so if there are any horrible mistake correct me to improve my English.:oops:
Monkeys1990
texas
Choose Engine Type
GX200
Yellow, Red, & Most Clone
212 Predator, Old Style (+$20)
212 Predator, New Style (+$30)
Blue (Lifan) 5-bolt Clone
GX160
Select Carburator
GX200 Bored - Gas
GX200 Bored - Methanol (+$20)
SA Extreme Carb - Gas (+$60)
SA Extreme - Methanol (+$70)
GX390 - Gas (+$40)
GX390 - Methanol (+$50)
22mm Mikuni - Gas (+$30)
Walbro PZ26 - Gas (+$110)
24mm Flat Slide Mikuni - Gas (+$140)
28mm Flat Slide Mikuni - Alky (+$150)
Select Piston and Rings
None
T3 Dished, genuine Honda (1.0mm Rings) (+$43)
T3 Flattop, genuine Honda (1.0mm Rings) (+$45)
Wiseco Forged (adds long rod) (+$115)
Wiseco Forged (adds long rod) FOR PREDATOR (+$120)
Select Valve Size
28.5mm Intake, 25mm Exh (+$90)
25mm Intake, 24 mm Exhaust
27mm Intake, 24 mm Exh (+$20)
Slect Compression Ratio
9 to 1 (22cc Honda head) (+$60)
9 to 1 (22cc Clone head)
10 to 1 (22cc Clone head)
10 to 1 (22cc Honda head) (+$60)
10.5 to 1 (18 cc head) (+$80)
10.7 to 1 (22cc Clone head)
10.7 to 1 (22cc Honda head) (+$60)
11.3 to 1 (18 cc head) (+$80)
12.5 to 1 (18 cc head) (+$80)
Crankshaft Type/Options
No Crankshaft
OEM Genuine Honda (+$80)
OEM Honda, Balanced (+$180)
.060 Stroker, Honda Core, Unbalanced (+$200)
.060 Stroker, Honda Core, Balanced (+$280)
.175 Billet Stroker (includes Wiseco Piston) (+$375)
Select Valve Springs
Single Springs
Dual Springs (+$20)
Select Camshaft
252 0207
252 0607
274 0207
274 0607
274 1007
285 0607
307 0807
Select Flywheel Type
No Flywheel
ARC Billet Flywheel (+$90)
Lightweight Aluminum w/PVL Digital Ignition System (coil & bracket included) (+$229)
Small Diameter Flywheel (+$180)
Super Light, S2 or 6602 (+$150)
Additional Options
Add Roller Rockers (spacer not included) (+$80)
ok this is a hop up kit from nracing.com, and i was thinking of going with
Dual Springs (+$20)
285 0607 cam
Roller Rockers
that is the set up i was thinking about im just not sure about the crank, valve size and if its a good set up so some info on that would be nice. thank you.
barney, ga.
Most of my experience is with flat head engines, so some others may be able to advise you better in some areas there. i will tell you this, high compression ratios can lead to pre ignition, detonation, which will rip your engine to pieces. Is this to run on gas or methanol?
What we need here is to know exactly what your going to do with your kart. Like I asked before, your kart is a dirt oval kart. Is that what your going to do with it? If your going to run on a track, what kind, how big, what surface?
High horse power modified engine make there power way up in the rpm range at the expense of low rpm performance. So a 20 hp clone engine wont be much good on a fun kart. Fill us in on your plans.
