Torque converter ?
dmax
mich
Kart had an old 400 arctic cat set up in it, I blew the motor. I found an 18hp kohler to put in it. The question I have I can I run the 40 series torque converter driver and still use the driven off the snowmobile set up
exenos
Project Nut
Unlikely as the belt is thinner and the driven is too large a diameter. Younmight be able to get the shaft turned down to the sled taper for less than a 40 series would cost, but then you would have to play with the clutching
B man
Tecumseh FTW!
Oliver springs,Tn
Hed never get the rpms needed to engage it.
dmax
mich
Thanks guys, looks like I will just get the parts needed for a 40 series set up
