You have GOT to be kidding me!! I have NEVER seen a clutch mounted like that.
In your last pic it looks like the PTO shaft is tapered?? All the other pics look like it is straight.
Mounting a clutch that way means that you are creating a HUGE weak point where it screws into the shaft. All the torque that the engine and chain is going to put on the clutch is going to snap it right out of the threaded hole.
It looks like some adaptor was made to go into the clutch bore to allow it to screw onto the crank.
If it were me, I would not be buying that engine because of the tapered crank. To get a clutch to work safely and effectively, you will have to machine the crank down to allow a clutch to fit on it normally.
As fot the pitch of the chain and sprockets - the distance from tip to tip on the sprocket is key. If 3/8 then it is a #35. If 1/2" then it is #40. Follow Toystorys directions regarding the chain
