Need help with some sizes
dreazoian
Los Angeles
Im selling my engine and the guy from craigslist asked
"What size is the bore"
"What size is the clutch"
and "what size is the chain"
Im not sure on any of these so here are some pics, hoping you guys could help me out.
According to your last pic, the PTO shaft diameter (and therefore the clutch bore) is 3/4", the most common for engines in our size range. Count the teeth on the clutch and give him that #. As for the chain- measure from the center of one rivet to the center of the next. If it's 3/4", then it's #35 chain pitch. If it's 1/2", it's #40/40. Not likely, but 5/8" is #50.
dreazoian
Los Angeles
Alright but is ur clutch 3/4 too because the clutch doesn't even go ON the shaft just bolts in next to it
You boobood there Chris, #35 chain is 3/8" not 3/4"
11hp shoud be a 1" shaft
dreazoian
Los Angeles
Heres pics of the clutch
You have GOT to be kidding me!! I have NEVER seen a clutch mounted like that. :ack2: In your last pic it looks like the PTO shaft is tapered?? All the other pics look like it is straight.
Mounting a clutch that way means that you are creating a HUGE weak point where it screws into the shaft. All the torque that the engine and chain is going to put on the clutch is going to snap it right out of the threaded hole.
It looks like some adaptor was made to go into the clutch bore to allow it to screw onto the crank.
If it were me, I would not be buying that engine because of the tapered crank. To get a clutch to work safely and effectively, you will have to machine the crank down to allow a clutch to fit on it normally.
As fot the pitch of the chain and sprockets - the distance from tip to tip on the sprocket is key. If 3/8 then it is a #35. If 1/2" then it is #40. Follow Toystorys directions regarding the chain
dreazoian
Los Angeles
hmm well im not too worried because im selling the clutch and engine together this weekend and getting a honda clone. and i measured the chain it seems to be 1/2 inch so its a #40.
dreazoian
Los Angeles
I am sure he knows what he is getting, but does he know what it all means?
Well im hoping he does! :eek: but when i talked to him he sounded like he was pretty experienced with these engines and clutches. He told me it was going to be used on a snowblower.
