techumseh throttle help
trekklee
Hi i have a techumseh hs40-55565k and i can't seem to figure out how to hook up my throttle cable to it
Step one: Identify the hand throttle lever on the engine- this is the lever you would normally control engine speed with. Step two, connect your throttle cable, and a return spring.
trekklee
can i like get pictures
and my throttle lever? i have no idea where....
im new with this stuff
trekklee
trekklee
So when i follow one of the links i found the throttle linkage but when i do it on my engine it leaves the throttle open all the way
Yes but i never got it hooked up to a go kart or anything
Great- so then my question would be "what lever did you use to change the engine speed while you had it running"?
That's what you connect your remote cable. Then, install a spring to always pull the lever back to the idle position.
Beach Bum
Texas
Here's another picture of the part that I think will simplify things for you. It looks like your throttle linkage except the cable attaches differently, using a cable stop. Your linkage was made to "push up" from below. You need a linkage that "pulls" from above. (If that's understandable.)
Just drill out the rivets holding your linkage and secure this one using the same holes and use the little nuts and bolts that are provided with the new linkage kit. Plus this one has provisions for a return spring, which your linkage doesn't have.
