Step one: Identify the hand throttle lever on the engine- this is the lever you would normally control engine speed with. Step two, connect your throttle cable, and a return spring.
and my throttle lever? i have no idea where....
Have you had this engine running?
How about a few pics from a bit of distance away, to see the whole motor.
Have a look at these links, they might help you out.
Tecumseh carb cleanup, servicing and troubleshooting
http://www.kichline.com/chuck/fixit/mowers/tcarb/tcarb.html
http://www.smallenginesuppliers.com...cumseh_L-Head_Engines_Service_Information.pdf
http://www.smallenginesuppliers.com...cumseh/Tecumseh-basic-service-information.pdf
http://home.earthlink.net/~edstoller/index.html
Great- so then my question would be "what lever did you use to change the engine speed while you had it running"?Yes but i never got it hooked up to a go kart or anything
