Ethanol Beast?
THE_SHRUB
Fantasmatissist
Ive got a 5 hp Tecumseh enduro engine. Its relatively new and I decided that for a school project i would convert the engine to run on E85 ethanol. I was just wondering if anyone knew how to do this.
From as far as i can tell, the carb jets simply need to be resized, which i dont know how to do. Plz correct me if this is wrong.
If what I said above is correct, i was thinking of getting a tecumseh carb off of a similar engine from as snowblower so that i have the ability to adjust the high and low speed jets. The current carb lacks the previously stated ability.
I am also aware that this will likely shorten the engines lifespan and make it difficult to start.
Any ideas much appreciated :thumbsup:
Kenny_McCormic
Kartless....
Michigan Troll
Ethanol is a wimpy fuel, real men run strait methanol.
You will need an aftermarket carb (a mikunni in the high 20mm range will do), you cant adjust one of those snow thrower carbs for alchohol. Some timing advance will also help things.
Justin
I agree! Nothing like 138 octane 100% methanol.
wow, i just got 2x suzuki katana engines. need minor work. where do i get 138octane 100% methanol at and how much per gallon?? lol btw is it easy to convert it to run on straight methanol???? lol
jr dragster T
Cold place
Sure it's easy if you have the right stuff. Where to get it? Go to Home Depot and buy Methyl Hydrate. It's only about $7 for 1 gallon.
jr dragster T
Cold place
Uhhm I already told him where to get it for dirt cheap. And dont go around a race track trying to buy fuel. It's not alloud in alot of tracks.
THE_SHRUB
Fantasmatissist
what carb do you suggest and where from? or at least how can i find out for myself which carb i need to get?
Kenny_McCormic
Kartless....
Michigan Troll
Throttle opening is a slide that blocks off the tube compared to a butterfly valve on the stock unit. You want one for its large selection of jets and lack of rubber in most(alcohol+rubber=no good).
jr dragster T
Cold place
Switching to methanol wont be such a big performance upgrade anyway. If your worried about engine life then going full bore on alky is not for you. I'd invest in a cam or something else.
THE_SHRUB
Fantasmatissist
the whole idea is not so much performance as it is to show that you can run an engine on an alternative fuel. Thats why i was going to go for ethanol initially. Im thinking of maybe buying this to replace the stock carb
http://elescooterparts.com/parts/gas/carb/pz22/PZ22_Carburetor.html
Think that will do?
O also im aware that its gonna kill the motor real fast...
Finally, would i need to remove the governor? Cuz im pretty sure i would
