It might take a bit higher of a gearing though.
What?
Am I wrong? I thought that if you had a weaker engine then you would be smart to gear higher to get some acceleration out of the thing, that is assuming the shaft can even take a clutch, I wasn't sure if pressure washers had tapered shafts or not.
Lower- with a weaker engine, you'd need to gear lower. Bear in mind that when it comes to reduction, a lower ratio is numerically higher. For example, a 6:1 reduction is lower than 5:1.
Lower.There I go getting higher and lower backwards again, I've done that in every thread. I was trying to say that he would want to roll a bit higher than 6:1.
Lower.![]()
