I don't know what to do!
209beast
I have a go kart and I'm trying to get it running but I don't know how to get the sprocket and brake drum on.
It has a gap between the tire and the clutch.please help me I bored.!!image.jpg
The wheel doesn't have nothing to put the sprocket on.
I can't tell if that's a sleeved live axle, or a dead axle. Do me a favour- pick the rearend off the ground, and spin one tire by hand. Does the other one spin with it, or not?
jman98
its a dead axle. as said above you need a hub to bolt your sprocket and brake onto
realfast89gt
Kart Krazy!!
cibolo Tx
I believe you need the type that is bolted directly to the left wheel hub. It should have the brake drum and the sprocket together.
