wiring on a 12.5hp briggs?
hotrodtodd
I couldnt find anything in the search so i'll ask here.I have a 12.5hp briggs on an old cart that i bought to fix up.when i got home i fired it up no problem,but the wiring was all hacked up so i rewired it yesterday. the problem was you couldnt shut it off so i wired the coil to the on/off switch.well when i cranked it after the wiring was done it smoked the coil.so the question is how do i wire this coil up to shut it off? Thanks.
Kenny_McCormic
Kartless....
Michigan Troll
What kind of coil? One of those all in one electronic deals? if it was one of the electronic self contained coil you simply ground the wire to shut it down.
hotrodtodd
Okay i thought about that but wasnt sure.Alrigt one more question,what do i do with the two wires from the altenator?Thanks for your help.
Justin
Also you can just put a pair of needle nose pliars in the hole when u want to shut it off :roflol: it works fine for me :p
Russ2251
AZUSA:Powered by LAWN-BOY
^Never shut off a engine by choking it. Causes cylinder wash down.
With all due respect Mr. Tyler, it sounds reasonable but isn't really true.
At least 2 of my engines were designed to be 'shut off' using this method. One is 70 years old, the other is 61 years old and were heavily used. Crosshatch still visible.
Also, choking tends to pull oil up from crankcase (past rings) to lubricate cylinder walls.
jr dragster T
Cold place
Huh and you ARE the one that taught me that never to shut off a engine like that. I know all of my engine's including my dragster if you tried to choke the intake to shut it off you'd flud the hell out of it.
jr dragster T
Cold place
Sorry Russ so you realy didnt say it. Ok I already know where you live *MUAHHAHHAHA* and the dragster is on it's way. With a few dents and scratches and a hydrolocked engine. Lol just kidding. I'd like to see you put my engine in your kart. beside's ripping the noram to peices it would probably shred the rest of the drive train too.
