Margay Bandito.. bare frame and need help with what parts to get..
MKII420
hey guys, it's been about a year since i last came on here.. but i just picked up a frame last night.. looks to be a Margay Bandito frame from pics i found..
i'll need to put together a shopping list of parts to build it over the summer and figured you guys could help me :lolgoku:
i'm still new to this, but it doesn't seem too hard. first i'd like to get it rolling.. spindles/axles's/bearings and wheels..
here's some pics of the frame and i'll be adding more pics when i get parts for it..
http://i125.photobucket.com/albums/p71/mkii420/IMG_20130515_065401_zps38d17264.jpg
http://i125.photobucket.com/albums/p71/mkii420/IMG_20130515_065350_zpsec49eff7.jpg
http://i125.photobucket.com/albums/p71/mkii420/IMG_20130515_065442_zps8ba589e4.jpg
MKII420
ok so i'm thinking this is what i'll need.. i'm going cheap on parts as i don't want to spend a crazy amount of money..
i'm still a newbie and i'm just gonna post the things i need help with at the moment.. i'll do some searching on here later on..
Live Axle, are the solid ones better than the tubular ones?
will also need something to lock the axle in place..
bearings.. 1"bore
http://static1.mfgsupply.com/media/...0fa2c1f0d1ba5e241f914e856ff9/a/z/az8211_2.jpg
then i'll need these guys for the bearings
http://static1.mfgsupply.com/media/...fa2c1f0d1ba5e241f914e856ff9/b/e/bearfl2_1.jpg
the hubs i'm not sure about.. for the live axle, are the wheels designed to just bolt onto the ends with a keyway in them, or would i need hubs to bolt the wheels to?
Don't cheap out on things like bearings; a few extra dollars could be the difference between life & death
With a 1" axle, you won't get a hollow one; generally, hollow axles start at 30mm.
I suggest you use a 1 1/4" solid axle on this...
The axle is locked in place with the bearing grub screws
That depends on what wheels you use. Having said that, racing kart wheels are usually connected via a 3 bolt hub which have a keyway & built in locking collar
crgcf
california
as the above post states, don't cheap out on bearings,cuz once they seize you will spend more $$ on new ones. 40mm rear axle would be my choice, and depending on budget, comet kart sales has a great selection of margay chassis parts.
MKII420
any suggestions? i was looking on MFGSupply..
hmm.. makes me wonder, the Coyote Free Roller cart i have has a hollow one with snap rings, and also has the bearing hangers with 2bolts like above.. i'll have to measure it to see if it's a 30mm but it looked a lil smaller..
gotcha.. so basically i'll need hubs for the rears because i'm def doing racing slicks with wide wheels..
for the hollow vs solid.. on the hollow, the snap ring is basically doing the same thing a nut is on the solid axles, i noticed those have threaded ends..
oh and thanks!!
MKII420
yea the 40mm might be too big lol but i'll check out Comet Kart Sales.. are there any brands i should just stay away from?
MKII420
also, what axle width should i get? i'd like to rund 8" wide wheels in the rear.. would 10" be overkill? not even sure if they make a 10"..
but as far as the look i'm going for, i want to have the wheels staggered and sitting low and wide
i just want it looking badass!! lol going to keep it orange or with a neon green.. i def want the frame a bright color, black accents and polished/shiny wheels..
fourtogo
Lot's more cheaper parts at 1 1/4 axle size. Bob4cycle.com tons of wheels bearings axles used stuff in good shape. BMIkarting.com for spindles .
MKII420
thanks mang! i'll check those sites! are the spindles basically all the same? as far as size goes? i saw some for over a 100 bucks and i was like ****.. that's a lil pricey, but if i can get some used that would be awesome! lol
