predator 212cc strong as gx 160
Raider Fan
Wichita, Kansas
Purchased amusement style go kart. Has a locked up gx160. Will a predator 212cc power it. I still want to use the body, which is heavy. The tires are 18x 9.50-8. Also what clutch set up should I use?
Use the clutch that's already there, if you can. Pay close attention. Some concession karts us a GX with a reduction gearbox on them. If you eliminate this gearbox, you will have to re-engineer the entire derive system in order to have an appropriate ratio.
Got pics?
Raider Fan
Wichita, Kansas
It does have a gearbox, will it bolt on the predator? I do have some pictures will post tomorrow. Having trouble postin pics, and telling a little about myself. First time building a kart.
I suspect the Honda has a special PTO shaft to facilitate the redux box.
So, you think Honda would use a different crank between the engines with a redux box & those without?
As discussed in this thread, the only difference is the clone shaft is 12mm (1/2") longer than the honda shaft. Apart from that, everything should be sweet...
I can attest to the fact that a Honda GX160 only has a 50mm (2") long shaft; as seen in the pics below, I had to make a 1/2" long spacer to mount a standard cent clutch.
Oh, & welcome to the forum
A predator will be even stronger than the GX160. The GX160 is rated at 5.5HP and the Predator 212cc at 6.5HP
The reduction box is a brilliant clutch system. I would keep it to avoid a lot of hassle
Raider Fan
Wichita, Kansas
I think I will keep the reduction box. I pulled it off last night and it looked good. Less hassle is good. With the limited use of my right foot, as with my car I had to get a left foot peddle for throttle. It has dual hydraulic brakes on it, do they make a hand brake with a master cylinder for steering wheel. I was told by my local shop, that use of a hand brake would not have enough pressure to stop. Thank you welcoming me. Glad I came across this sight. Haven't picked up a wrench over a year and a half, sure feels good! Pictures to come.
Yes- I do think that. Not written in stone though, I haven't had one to look at. Pretty sure I read it somewhere, though.
Sure! Grab the handle/master cylinder assembly from a motorcycle!
Raider Fan
Wichita, Kansas
The shaft on the honda is slightly bigger than the predator. Just enough to have a little play. About the thickness of a dime all the way around. The keyway is also narrower. I thought of using a thin steel sleave over shaft, and cutting a small slit in it for keyway. The bottom half of key hand file so it'll fit both keyways. It's not much that has to be filed. Any thoughts?
machinist@large
West Michigan, 49331
Could you take some detailed photo's for us? As the old saying goes, "A picture is worth a thousand words."
:cheers2::popcorn:
traxxaskid
RI
More than likely, the honda shaft is 20mm whereas the clone is 3/4" (19.05mm)
You can get shims that will fix your problem
This one is for a bicycle seat pole but could be adapted to fit the PTO shaft
Raider Fan
Wichita, Kansas
Thanks for the shims idea. Trying to download some pictures of kart when I first got it. I also got a handbrake and master cylinder. Thank you guys for the help.
