centrifugal clutch issues
vinny
okay so i'm new to the forum picked up a beast new manco magnum express its a 169cc 6.5hp its powered by a centrifugal clutch is there a way to possibly change it from the centrifugal clutch to sprocket set up its a robinson subaru motor i'll post pictures whenever i get them off my phone in a few minutes the cart runs i got a great deal on it just heard that sprockets are better
thank you all
vinny
pics added
tried to add pictures hope it worked sorry for the mess and the rotation issues took em with my phone... also along with my previous post what can i do to make this thing "run"
thank you
Ok, I'm confused: Nearly all karts that have a centrifugal clutch have sprockets...
Edit: Ok, that's not a cent clutch, that's a torque converter &, trust me, you wanna keep it on there.
Some detailed pics of the rear end in the correct aspect (rotate them before you upload them) will help
vinny
i was told this does not im not sure though this is my first one i've ever worked on for being 19 and a male its upsetting
vinny
rotated them
...does not what?
What we need to see is the rear axle setup.
There should be a small sprocket behind the driven (the larger of the two pulleys) which attaches to a large sprocket on the axle via a chain
vinny
best picture i have of the back until tomorrow
vinny
is there a way i could adjust the spings to get this thing off the ground a little bit few inches also what can i do for more power thinking of investing in a 440cc snowmobile engine
If you have good fabrication skills, then the sky is the limit. If not, then I would not be thinking of a sled engine. It is not plug and play
