fowler
Never underestimate the important of maintenece and the importance of getting the correct engine specs
This engine is a cat 3512 a 51lt C12 making around 4000 lb ft of torque
This engine was sent back from site as as a non running unit with piston 11 and 5 being suspect
After pulling heads 11 and five we found
Head 11 had dropped 2 valves and bent 1 and 5 was full of metal with 1 bent valve
Both have destroyed pistons liners and heads
This destruction caused a huge coolant leak that filled every piston and the after cooler
Bits of valve went though the turbo and took out a few fins that's written off
The reason for this
A valve set that went wrong
Before we pull down any engine we check all specs
The valve specs are 20 thou intake and 40 thou on the exhaust
The Injectors are allowed to be 10 thou out
All specs were 30 to 40 thou out
This caused excessive play in the push rods that snapped the cam follower clips
The follower twisted and ate out the shaft
This caused a severe slap in the valve train that punched the valves out
We had alot of damage but couldn't find the last piece of valve
It was in piston number 1
The engine is stripped right down now
The cost
Around 5 for the cam shaft
Each liner, piston set 3 grand
Turbo, got a spare
Heads, got spares
And another few grand in gaskets and other parts
All because someone stuffed a simple valve set
The reason for this
The cost
Turbo, got a spare
Heads, got spares
