1" clutch on 3/4" shaft?
newrider3
Colorado
Thank you very much for the offer, Russ. I'll look into the shim stock first before bothering you though.
crazycart
RedNek Engineering
MINNESOTA
I think you should start selling those as kits, get up a ebay store. You could make some good money. I still think i could make my own kit a lot cheaper.
sayre315
Rupp enduro
Oklahoma
well from wat i was told the aluminum alone is around $50 depending on where you are and where you buy it
and the amount of time it takes to do somthing like that
i mean, you got to make a hole for the exhaust, the shaft and holes for bolts + towards the bottom there is i think 4 slots that look to be around2"-3" long
jr dragster T
Cold place
^Exactly, Russ has to make some profit off of it for it to be worth it. Just like my Rhino engine in my car. $2000 in parts and it ended up costing $4000 when the motor was all said and done.
Jerryburger
Admiral Annoy
The Nation's Catbox...er, AZ.
There's gotta be some way from our standpoint of getting around the clutch issue. That maxtorq 7/8" i.d. clutch being offered on Ebay is way overpriced. Gotta figure something out. ****ed vertical engines and their oddball shafts!
