Mud buggy
Arkyhunter
Benton Ar.
watching all of you building a buggy I thought I would give it a try.Just reworked a sst motorsport kart for my grand daughter.So I thought Id make me something to ride with her.
Vance
mysteryboy28
Lansing, MI
not sure if you've got the torque converter bolted down like that, but you actually want as much distance from the torque converter sprocket and axle sprocket as you can reasonably get. reason being that if you have a small 10 tooth sprocket right next to a big 60 tooth sprocket, the chain tends to slip right over the smaller sprocket if there's ANY slack. now move the 2 farther apart, and the chain wraps around the smaller sprocket better, and you have much less chain slippage.
so... if that's how you were gonna bolt the TC on - don't do it! flip the driven clutch side up so that the assembly is at a 90 degree angle, giving you as much distance between the 2 sprockets as possible! sure, you'll need a longer chain - but it'll totally be worth it!
now if you were planning on throwing a jackshaft into that mix for further gear ruduction (more torque!), then ignore my above comment, because you will be going from closer-sized sprocket to sprocket, which will improve your chain grab.
Arkyhunter
Benton Ar.
Thanks for the info but thats the only way it will bolt on. But I can slide it back & forth. I may have to add a jack shaft. Thanks again.
Sent from my e1101_v73_jbl1ctp_a515 using Tapatalk 2
Arkyhunter
Benton Ar.
DuroMax 16hp but I dont plan to use it long. I got a 250cc 2 stroke four wheeler motor im going to put on later.I want to rebuild the topend first.
Arkyhunter
Benton Ar.
Yep its a bit light but I was told it was rated up 13hp.If it last long enough that i can get my polarasis 250 motor ready ill be happy.
Some of the knock off comet 30 series are "rated" to 13HP. This is just to get you to buy them. A genuine Comet 30 series is only rated up to 8HP, so I don't think a knock off would be able to handle more. You could probably push a genuine TC to 10HP, but you are still going to be going through belts quite fast
Arkyhunter
Benton Ar.
I wander why they don't sale the comet 40 in a kit.How would a 40 driver with a 30 driven would work.
mysteryboy28
Lansing, MI
here's the deal. unless you're ready to fork out $200+ on a comet 40 (clone) setup - it looks like you will need to make a jackshaft for sure. change your gearing to around 8:1 and you should be ok till you're ready to throw in that ATV motor. by lowering your gearing it will put less stress on the belt. you'll have plenty of torque, just not a ton of speed.
use this calculator to determine what ratio you need depending on tire size to get 24mph (the sweet spot using the under-rated comet 30 with a too powerful motor).
http://www.diygokarts.com/speed-calculator.html
with 18 inch tires you need an 80t axle sprocket and a 10t clutch sprocket. that would be a gear ratio of 8:1.
now go to this calculator and play with the numbers to determine realistic sprocket sizes to achieve the 8:1 ratio.
http://www.affordablegokarts.com/GearCalc.php
Arkyhunter
Benton Ar.
Ok been playing with the gear calculator and I havent come close to 8.1 .So can someone give me a starting point.I got a 12t and a 72t on kart now.And I run a 40 chain.
Thanks
With a 12T clutch, you are going to need a 12*8 = 96T axle sprocket. This is not practical because it could be larger than your rear tyres. This is why you need a jackshaft.
You could use your 12T clutch, a 36T JS in sprocket, a 24T JS out sprocket and then your 72T axle sprocket. This will give you (36/12)*(72/24) = 3*3 = 9
You can obviously change things around a bit and use different sizes, but you get the idea
Arkyhunter
Benton Ar.
you know theirs alot of old tractors etc used belts and idle pulleys for a clutch.I wander why you dont see this setup on karts.I know of a old tractor that the motor slides back and forth to tighten the belt and the old mans been using it for years its a 18hp i think.
Arkyhunter
Benton Ar.
I got a little done today its he** work for hours not have much to show for it.But I got some work done on both ends.Also got my parts for my jack shaft too.
Arkyhunter
Benton Ar.
Got alittle bit done today got my front end done .But I some how got my toe end off on the right wheel so l"ll have to fix that.Found me a temperary seat laying beside the highway lol.And got a start on the cage.Im ready to get to the motor end so I can ride this dude.
Arky
Arkyhunter
Benton Ar.
Well it finely stop raining weekends around here so got abit done.I made some changes to it a better clutch off a polaris 250 .Got the motor bolted in and removed the govenor ,made a header out of a cushman kart pipe.Plus a few frame changes.So what do you think so far.
Arkyhunter
