Cooling down engine
trekklee
Sheet metal. Tin. The metal work that the pullstart is bolted to, and all parts connected. The PAINTED stuff!
EDIT- The engine itself is aluminum. The stuff I'm talking about is steel. If a magnet sticks to it, take it off!
the magnet is not the wheel is called a flywheel right??
trekklee
Is this a joke....????
OK trek, A motor like this has fins all over, they help it cool it.
Here is some sheet metal parts on a similar motor.
They cover parts of the motor to channel the air over it.
These are not my pics, I found them on the google search.
http://i957.photobucket.com/albums/ae54/oldminibikes/IMAG0180.jpg
http://i957.photobucket.com/albums/ae54/oldminibikes/IMAG0179.jpg
So should I take off the gas tank??? Cause its on top of the engine and I think it blocking air
fowler
Bullsbrook West Aus
The fuel tank is mounted over the crank case
The heat is coming from the head and cylender
Just take off the couling and clean the fins
Also ensure the flywheel has all its fins
Also what are u calling hot
The block will always be too hot to touch
And something like a lean engine will cause exesive heat
trekklee
Can I take the gas tank off like this would it help???ImageUploadedByTapatalk 21363805296.177350.jpgImageUploadedByTapatalk 21363805306.322917.jpg
Treklee, I have instructed you to take off the metalwork for CLEANING. Not to leave it off. And NO- leaving the gas tank off will make NO difference.
Well, that's part of it- that bit labelled "shroud". Now- depending on your engine (I have since forgotten what you have) it may have additional peces that need to come off in order for you to clean all those fins.
trekklee
So just to verify this is a cool fin???? In the top
Trek where abouts are you from. Perhaps we are not communicating properly and that is the issue?
trekklee
Well I don't know a lot about small engine but they are similar to car though
I'm more of a car engine then a small engine
trekklee
I spray something I the fins so it could come off easily cause I'm using a big air compressor and its still dirty
fowler
Bullsbrook West Aus
just occurred to me that you are the one in the other thread
the engine is running too hot and it is lacking power
a long list of issues can cause either symptom
but what causes both is running lean
look in your other thread
i will put a link in there on how to clean your carb
u should also continue to clean the cooling fins as it will certainly help and will erase any fire hazard
if there is rust and dirt buildup on the fins then u can use a wire brush
if u get real keen then u can wire brush the whole block back to bare metal and paint it with special engine paint
trekklee
But doesn't painting it cover the fins from cooling down???
