Predator Modded Now its Dead . . PLEASE HELP
set2stun
Falling is just flying without ascension
Myrtle Beach, SC
I'm glad you reminded me to keep the governor attached to the carb because i could easily have seen myself forgetting and hooking the throttle directly to the carb. Now i have to figure out how to setup the linkage via that top plate. But i'm glad you say that i don't have to worry about anything but the governor destroying the motor. I don't mind destroying the motor if worse comes to worse but i don't want to be physically harmed.
-Yeah- Nothing fun about losing valuable body parts...
Have you read this?
With the stronger valve springs in, I do NOT suggest a governor-ectomy without hi-po rod and 'wheel.
set2stun
Myrtle Beach, SC
Thanks so much Toystory and great post. So if i don't remove the governor i should be alright with the mods i have made? I am only concerned with personal harm befalling my body and don't care if the engine gets damaged.
Nah- With the governor intact, adjusted correctly, and functioning- it'll be fine. Just (as is with ANY engine) stay on top of maintenance.
realfast89gt
Kart Krazy!!
cibolo Tx
You do know the Edit button allows you to edit your post, so you don't have to quadruple post, right?
Are you serious? I posted 3 times, not 4. How about shutting it.......i have never seen someone complain about posting 3 times in a row and it isnt even your thread........:2guns:
Easy folks. Let's not start something here.
We generally DO prefer that folks avoid multiposting, but the really annoying ones are a half-sentence at a time, spread 30 seconds apart.
realfast89gt
Kart Krazy!!
cibolo Tx
I understand. My problem is when i post 232 times and have never "multi=posted" and the one time i do it someone has to point it out like that(over-exagerating).........not needed. Me replying was equally not needed but it was to point it out.
I am done.
I used the "edit" button to write this sentence.
