devino246
Official DIYGK Chem Nerd
the rad is still out, i plan on ordering the one from rock auto this weekend
are you talking about the new shiny plug in the water outlet? i put that there because the sensor was broken anyways, no vaccum lines anywhere to be found. and it hit against the fuel line
wouldnt i have to pull the engine to get to the camshafts? or can i access them through that block behind the water pump. i would have to remove that big pulley too right? how much of a job is that?
my local auto store said the cheapest rad they can get will be $500, the rock auto one is $200
Typical :toetap05:
You'll have to pull anything directly in front of the cam (like the radiator and grill insert), but it just slides right out the front of the block. I haven't taken one out of a 335 series engine, but it's right behind the water pump drive. I'm sure you could figure it out. Believe it or not, my passing the Engine Repair ASE was nothing short of a miracle (ok, I'm just really good at tests). Your knowledge of engines probably isn't too far off mine
