I like karts
Rotary Power!
If I have A torque converter (when its in the low ratio of 3:1) and a 3:1 ratio from the jackshaft to the axle, am I getting a 6:1 ratio? Or do you multiply and get a 9:1 ratio?
I believe it would be 9:1 because the engine would rotate 3 times to make the jackshaft rotate once. The axle requires 2 more rotations from the jackshaft after that to rotate 1 time. So the engine needs to make 9 revolutions before the axle rotates once.
