1978 f150 flareside project
Bluethunder3320
i dont know if theres any scrap yards near me. yes i still have the bmw and its still burning oil haha. using that as my daily driver. i got $500 for the 89 f150. and $150 for the visor. truck had a bad clutch, patched frame, bad cab mounts, blown p/s pump, broken leaf mount
a rebel flag would make a nice head liner but my parents are strongly against the flag and a lot of people are here in ct
heres a vid of it runnin on all 8 cyls... sorry its dark
Bluethunder3320
got it registered and went wheelin today. nothing broke! i dont have pics but my friend took a lot of videos and ill post the link when he puts it up. crossed a frozen pond and got stuck going up an icy hill but i made it up. burned 12 gallons of gas today! lol. love the short wheel base it does a lot better off road then my 89 and lots more power but its a rough ride
Bluethunder3320
yeah i did that when i was stuck on the hill. but also did it on flat ground and i had no problem shifting it
devino246
Official DIYGK Chem Nerd
Lynchburg, VA
Oh, also, you may want to buy a spare ignition module to keep in your truck. The Duraspark (nicknamed "neverspark") ignition modules are bad about going out. When they go, it's usually like you just shut off the key. The ignition module is the silver, finned box on your inner, driver's side fender.
Bluethunder3320
would it be damaging it if im not rolling back?
got a spare one behind the seat but it looks used... not sure if it works, i should plug it in and see
Bluethunder3320
noticed coolant leaking from the radiator. its coming from the seam below the inlet. the rest of it is pretty beat up so i decided to just buy a new one.
i bought a new standard size rad (same as original not a plastic one), top and bottom hoses, heater hoses, water pump, 14,400 BTU tranny cooler, tranny lines, plastic glove box insert. from bronco graveyard
devino246
Lynchburg, VA
Sounds like you've got a busy weekend ahead.
I should probably mention two common problems with the 351m: prematurely worn main bearings, resulting in knocking and low oil pressure; and worn timing chain. Please note that the factory gauges in these trucks are HORRIBLY inaccurate.
Bluethunder3320
ive heard about the timing chain issue. theres a nylon sprocket that gets worn out on the crank? seems like the only way to fix that would be to pull the engine and tear it down...
my oil pressure starts off higher when its cold and gets a little lower than half when its warm. ive checked the oil and its normal (but the guy says the dipstick is from a 5.0 mustang)
worn main bearings would result from crappy oil right? as long as i change the oil often and warm the engine up before driving it should i worry about this?
the guy said it had a C6. that would mean 6 speed right? im pretty sure it only has 4 gears. the last shift is around 40mph. on the highway today i got it to 60mph but i was revving the engine way too high to stay at that speed. i kept it at 50mph.
my friends got a 460 and zf5 he wants me to put in it. hmm.. guess i got a backup
newrider3
Colorado
lolno, C6 is a three speed auto, no lockup in the torque converter, 1:1 high gear. Bulletproof but eats a bit of power and mileage.
Do yourself a favor and invest in a mechanical triple gauge set (oil, temp, volts), even the cheap set from Harbor Freight will give you some peace of mind over the stock gauges and idiot lights.
devino246
Lynchburg, VA
The chain just wears out and lets the valve and ignition timing jump around. If it gets really worn, the chain can jump teeth.
That's normal. Oil thins out as the engine heats up. Like I said, though, don't trust those gauges. You should find the proper dipstick.
The bearings just wear prematurely. Cheap parts, design flaw, or something. Mine had to be replaced at 120,000, along with the crank redone. Luckily, the PO did it.
C6 is only 3 gears. Great transmission, like newrider said. Should shift about 15, 25, 35, depending on load and throttle angle. You're going to be over 3k at highway speeds, which isn't a problem. Welcome to old trucks.
Swapping in a 460 and zf5 is alot of work. It's alot of custom fab that the average hobbyist can't do.
B.M.800
TheBeal.
Central PA
I dont know about a stock one, my brother was talking they could be built up to make as much power as its big brother...
B.M.800
TheBeal.
Central PA
Good question, my answer would be that people like to make things complicated. lol.
But yeah, I can find a 90s dodge for about 2-3k for the whole thing, Ide be paying that much or more just for the 4bt.
My brother was telling me one of them smaller cummins out of like a frito lay truck would bolt right in an 70s Dodge pickup.
