building a kart frame
NB1015
hello i am from virginia. i recently purchased a mig/flux welder and i plan on building a kart. i would like to use a 125cc 2 stroke if i can find one for a reasonable price. if not ill probably find a b&s or honda 4 stroke. but to get started i want to build the frame myself. i have found one set of complete plans. just seeing if there is anything else out there for a road racing type kart using a 2 stroke, live axle and i would like to use cable disc brakes if that is possible.
DS13
Annoying the Neighbors!!!
Elysburg, PA
look at my thread in my signature because you will have the exact same setup as me:thumbsup: but if you decide to run a 125 2 stroke you will need hydraulic brakes.
You're new here so, just a heads up, multiple threads on the same subject are a no no; chances are they'll be merged before too long :)
NB1015
yea im sure ill hear about it sooner or later. whats the best way to setup the front steering and angles. i really just need to buy a built frame, as much as i want to build my own frame it just seems to much for me at this point. limited space and funds.
DS13
Elysburg, PA
if you've decided to not build your own, buy a frame that is sorta common so you can find parts easily and have more help building.
