If anything, there's not enough slack; the belt shouldn't grab until you get on the throttle, nor should it rub on the driver. If the belt is grabbing at all at idle it's too tight
Fabroman, landuse it doesn't creep at all but I only allowed it to run for about five minutes. I was afriad of damage without more info. I thought to that the belt was still a little tight even with the slack that it has, however I have never seen one together before. How do I go about adding more slack? Should I be concernabout the chain as well?
