tire rim size info???
Xenogear_id
hello people, im learning on what fits on what with tires and rims.
i plan on putting i little bigger tire on the back of my manco kart.
i found the tires i want but i need to know what rim to get. i have the links below. im kinda get but need to know how to read the info .
example, 145/70-6 how do i read this? i think 6 is the rim size? im a noob sorry.lol
will this tire fit on this rim? if not whats the right rim size for this tire? thanks for any help.
tire
http://www.bmikarts.com/item/15-Turf-Tire-260116-101
rim
http://www.bmikarts.com/item/Split-Rim-6-262006-288
qtband
St. Louis, MO
That tire will fit that rim. Now, will that rim fit your kart?
The last number in the sequence is the rim diameter.
The "turf tire" is a squared tire. Nothing wrong with that, especially on the back.
The 145/60 are rounded. They look good on the front.
Metric sizing works like this-
Section width/Aspect ratio-Rim diameter
The first number is in millimetres. The section width is nominal measurement from the widest point of the sidewalls. 25.4mm= 1 inch. So:145mm/25.4=5.7" at the widest point.
The aspect ratio- is how TALL profile of this tires is, COMPARED to the width, expressed as a percent in millimetres. 60% of 145... So 145x.6=87mm/25.4=3.42" section height.
The third number is rim diameter expressed in inches. To figure out total diameter-
(Section width/aspect ratio)x2+Diameter
3.42x2+6= 12.85"
Like anything, this is nearly NEVER what the true measurement works out to.
Hang on; in the case of car/truck tyres, that's true. However, in the case of the tyre in the link above (& others like it) those rules don't apply.
A 205/50/15 car tyre has a tread width of 205mm, a wall height of 102mm (50% of the tread width) & fits a 15" rim
A 15 x 6.00-6 tyre means the total height is 15", the tread width is 6" & it fits a 6" rim
Well- THIS was the example given-
So... It's not solely car/truck tires, it's any Metric sized tire. I realise the one in the link is not metric, but he asked about a Metric size.
Xenogear_id
thanks for the info guys. i do plan to use 145/60 in the front. well here are some pics to show you guys to see if the rims and tires i linked above will fit on the back. and i also took a pic of the hub witch i will also be replacing.
Is that a dead axle? On a kart that size? IIWM, I'd be converting it to a live axle. Doesn't look like it would be too difficult either &, since you're changing everything anyway...
qtband
St. Louis, MO
Can't see the motor mount since it's covered up. I would guess that it could stay where it is. You would have to weld on some axle hangers and get a hub for a sprocket. Then you'd have to do something for your brakes. That is a big kart for a dead axle.
