MrPenguin9
Firstly, I am sorry for my lack of knowledge. I have tried googling but I couldn't find any straight forward answers. Secondly, I don't know the terminology that well, I have never done anything like this.
Ok, I am trying to build a project based on this(see pic 1) It is basically a balancing one wheeled skateboard. So far the only part I have is a wheel (see pic 2). Now from what I understand, I'm going to need two bearings attached to the body, an axle between them, a sprocket(being spun by a chain to the motor) attached to axle, and I need the wheel connected to the axle. But how do I connect the wheel and sprocket to the axle? I have never welded before. I could try to teach myself, but I think permanently welding the wheel on to the axle could become a problem if need to change the rim/tire. I read about a hub that I can connect from the wheel to the axle, but how do I know if the hub will fit on the rim? (like would this work? Ebay Wheel Hub) Also the hole on the rim is about 45mm, what size axle should I use? (40mm?)
Thank you guys so much!!
Tyler
Tyler
