Kaptain Krunch
Pro Junk Collector
No sillycone. Take pictures of said sand, and the rest of the engine up close. There is no way any of us can give u good direct advice without a good idea of what your working with.
could i just use silicone as replacement for seals ?
NO, NO, NO! Don't be the silicone homo.
Quote Kaptain Krunch:
Also, if you want to attempt to re-use the head gasket, and its the fiber type, apply a thin coat of brake fluid to it, which may help it swell up. If its a metal head gasket i suggest getting a new one.
I've never heard of this brake fluid trick on fiber gaskets. I'll have to try it. Have you ever tried Permatex spray copper on your metal gaskets? I've had good luck and know of many others who have also. You can reuse these many times. Just clean the gasket and put a nice even coat on one side, let it dry over night. Flip, then repeat. Not too much or it will try to squish out like silicone. If this happens there's too much on it. Nice thin layer, just enough to make it look like it's a copper gasket. This should serve you well.
