Finally, i have the engine and kart.
HaM551
Perth, Western Australia
ok so i picked it up today, il have some pics later after i have cleaned most of the stuff off, the kart frame is a CIK 10 :2guns:
so the engine is a 250cc :D, im so gonna kill myself on this thing ( if it works) :D
and has a LOT LOT LOT of dirt and sand and oil mixed into a paste covering it, what is the best way to clear this stuff off ? can i attack it with a hose ?
and secondly the exhaust is open and there is a lot of sand and stuff down there as well, is that bad ? how am i supposed to clean that ?
Finality the motor is missing some bolts and some are loose around the engine, but they might be mounting bolts.
Ok so ima try clean this thing up and take some pics for you guys
FatCat
2 stroke Addict!
Ottawa, IL
Sand in the exhaust??? I hope your meaning the pipe not inside the exhaust port. If the engines full of sand that's a really bad sign. Was this manually put in there by kids or something? It will definately need disassembled and all of this needs to go. Sand is a death sentence to an engine. In a hurry.
HaM551
Yes assuming i am not mixing up the carb intake and exhaust intake, but both have sand just around the inside, the one i think is the carb intake only has it an inch or 2 in, but the exhaust has it 2 inches in and a few specs down the bend?
How far would i need to take apart the engine? it is a 4 stroke so would this be risky ?
will post pics tomorow when sunny
sno-kart
The possibility of sand in the engine is a bigger risk...
2 or 4 stroke, water or air cooled?
+1 ... if you think there is even a 1% chance that there is sand inside the engine, take it apart and clean it up before you even crank it over.
someone said a Honda CG Service Manual would be usefull
Well, that's true...
You should be able to clear everything by removing the head, carb & exhaust & use compressed air to blow everything out. Try to avoid wiping as that may cause scratching in places that aren't meant to be scratched. Some Diesel or gas in a spray bottle will aid in collecting any sand instead of just moving it from place to place.
Also, be sure to turn the engine to open the valves & clear any sand that may be caught between the head & the seat.
Once you've cleaned the engine, repeat the process with the carb & exhaust, making sure to blow out away from the mounting surfaces. The carb may need a bit more than a simple blow through...
Would I take out the piston and check cylinder ?
No, just wind it down to the bottom. You should be able to see if the bore is damaged
Will I need new gaskets and seals ?
More than likely, it depends how careful you are taking them off
And I have heard about top centre or something? What's that ?
Do you mean top dead centre? This is the point where the piston is at it's highest point in the cylinder. Obviously, bottom dead centre is when it's at it's lowest point
Not sure where I can get gaskets and seals for this engine to how can I reuse them ?
Take them off veeery carefully; get out the stanley knife... :D
Yeah top dead centre do I just turn until piston is at top ?
Correct but, don't turn it until you remove the head & clean inside. If any sand did manage to make it's way inside, you'll score the bore, the piston & the rings. Do that & you may as well say goodbye to your engine...
HaM551
so after taking everything off, i get to the cylinder and piston, pull the piston down to lowest point, inspect, if no sand pull it up to top dead centre then start rebuilding ?
And the engine has 172FMM on it with a star then 06035668 and another star, when i search 172fmm i get a lot of results, i also noticed gasket and seal backs for 172fmm model engines, would those most likely fit my engine ? but those are all for a Zongshen ZS250GS, recon its engine from that bike ?
Kaptain Krunch
Pro Junk Collector
vermont
Im not sure tearing this whole thing apart is something your going to want to do, if you've never done it before. It is likely a chain driven cam, and timing is pretty easy to mess up if you dont know what your doing. If you do take it apart, be sure to mark the chain and sprockets in multiple location.
Also, if you want to attempt to re-use the head gasket, and its the fiber type, apply a thin coat of brake fluid to it, which may help it swell up. If its a metal head gasket i suggest getting a new one.
HaM551
how would i get the timing right and the chain driven cam right ? and my plan it just get to the cylinder, im not gonna mess with the gears unless i have to
Kaptain Krunch
Pro Junk Collector
vermont
If its an overhead valve you will have to mess with timing chain/gears.
HaM551
Im starting to get twitchy, i want to start on the engine, but i need a carb + exhaust + shifter + sprocket.
And i would have to reuse the old gaskets and seals. Should i just do it ?
