Manco 445
danny62630
IL.
Hello all new to the site, so I have this kart with a old B&S 5 hp(135212 0006-02)is there any motor out now a days that will fit just like the old does? Let me know if u need more info.Thanks for any help.
What's wrong with the Briggs?
Unless you are swapping in an identical engine, something will have to be changed. At the very least, chain length and throttle control. The bolt mounting pattern of the ultra-common Honda GX200 and clones will likely be the same.
danny62630
IL.
Wow that was fast toystory thank u very much for the info. The motor it's self is in bad shape smoking real bad I thank new rings are needed but not sure,all seals are bad to so I was looking for something different.
danny62630
IL.
I've never rebuilt a small motor befor(any motor) but yeah I'll try to find a new motor and look into the rebuilding it, thanks for all your help
There's only one way to learn...:)
Seriously, it's not that difficult & we can help you along the way. One of our mods (landuse) is still in the process of rebuilding his first engine :)toetap05:) so it's never too early or too late to learn...
Mcbreja
Arlington, TX
He still hasn't gotten that adapter?!?!? Holy :censored:!
Sorry guys, I don't know what to say. I saw the guy starting to make it last week, and now he says he is busy again. It seems like my job is so small that any sort of work that comes in gets done before mine
Man, you could've filed the darn thing by hand by now :roflol:
That's just lousy customer service.
I don't know what to do. The worst is that I know the guy. It seems like all the machine shops seem to dismiss the small guy until they have a bit of free time that they can fill. I feel like pulling my hair out
It's been long enough that I don't even remember what you need machined.
That kind of thing just burns my hide. You might have a small, insignificant job THIS time. What happens when a big job comes along? I'd take it elsewhere. So much for building a customer rapport.
Mcbreja
Arlington, TX
I'm not sure what you're apologizing for, it's not your fault.
Anyways, Danny, with the help of this forum and some research, you can probably get that engine running. It's worth taking a stab at. The worst case scenario is that it just isn't fixable and you wasted some time. However with the trade off being that you learn something, I'd definitely say it was worth it.
danny62630
IL.
ok guys i got the motor rebuilt every thing went back together really well no more smoke and it had a stuck valve all go to go now. Ok so i have been trying to hook up the carb linkage with out the governon for 2 days now, i did a search of this site with out any luck so if anybody has some tips or a link it would be really cool. Thanks for any help
There are many different ways to connect a throttle cable to the carb, it's just a matter of using your imagimation... You can use linkages or connect the cable direct to the butterfly; the only two things you need are some way of connecting the cable & some kind of stop for the cable sheath.
Using the search function, have a look through the forum for different setups & take your pick; just about every kart is different coz there's not "standard" or "one size fits all" setup...
danny62630
IL.
ok ill look agin im not having much luck, but ill try it agin. thanks for your time, im trying so dont get up set with all the Q...(not like u are im just saying)
