bike motor for buggy
FatCat
2 stroke Addict!
Ottawa, IL
A small fan?
The biggest thermo fan u can find running as hard as u can make it
I wouldn't bother
U will have an oil cooler with a thermo fan and this buggy won't be able to run slow under load For any extended period of time regardless of a fan
Really??? What happens to an air cooled engine to cool it? You move the engine through the air and air moves across the fins. Whats the difference between that and mechanically moving the air over the fins? The fan replaces the need to be moving for this to happen.
fowler
Bullsbrook West Aus
Because a bike has air flowing over the entire engine and the air is hitting it at 60+ kph
A thermo fan won't replace that
Look at statipnary engines and the air they put out
A lot more plus it's directed straight to where it's needed
Maybe a big thermo from a 4x4 or truck
Swabbster
the bike was not very good, i looked at it, it had no oil the right side spark plug was black the left looked great, it did not come with seat gauges, all beat to hell, so back to searching, im aiming towards liquid or fan cooled,
r97
Measure twice cut once
Massachusetts, USA
The bike was not very good when I looked at it. It had no oil, and the right side spark plug was black, but the left looked great. It did not come with a seat, or gauges, and it was all beat to hell. Back to searching... I'm aiming towards a liquid or fan cooled engine.
Where are you located? What kind of work are you willing to do on the engine? I'm guessing not much, so you probably want to save up a little more before getting a motorcycle or ATV. A two stroke snowmobile engine would likely be better if you are looking for simplicity/easy to get working.
Please look back at my post about examining an engine that you are planning to buy. Just because it looks bad, or has a fowled plug, doesn't automatically make it junk. That said, I think you made the right choice. From what I have gathered about your project, it probably was far from an ideal power plant. Don't give up searching, check craigslist once or twice a day and you will find something eventually. Also be sure to post up a wanted add, that is how I got the bike for my buggy.
P.S. What ever you buy, make sure it isn't stolen! Craigslist is full of thieves, and people who like to stretch the truth.
Swabbster
hey ya, it may have had carb problems, but usually oily caked on plug means something is ****ed, i allready posted a want add, but the reason i did not buy it is because it was in pieces, gauges were missing, it had no oil, only a bill of sale, but its easy to make a fake bill of sale,
FatCat
2 stroke Addict!
Ottawa, IL
A really good engine to use would be a Rotax 583. I'm not sure what your budget is but I'm not sure you would have been satisfied with the power. The rotax's put out 103hp stock. If your patient and watch craigslist you could find a whole donor sled for $500 or so. Look for something wrecked. While searching search "ski doo 583 rather than Rotax 583. This would tale you to a CVT also which is great in a buggy. That is unless you feel an absolute need to shift.
FatCat
2 stroke Addict!
Ottawa, IL
The FL350's had overheating issues. This is the cheap way to correct it and it works great. The biggest heat build up in an engine is on the top of the exhaust side. If you focus the fan here IMO you do a nice job if replacing the airflow. It's not 100% as good but sure beats sitting there baking every time you stopped.
Swabbster
ya the bike was 50, i will have to see what kind of deal comes up, i may spend 100-1000 for a good motor, i have a lot of time, i don't want to just throw it together, it will be all gusseted in, very strong,
