bike motor for buggy
Swabbster
i will be buying a 1983 suzuki gr650 bike soon, how hard is it to set up the wiring out of the bike, i dont want to pull the whole wiring harness out because there is alot of crap i will not use, what parts of the wiring harness has to come out?
soggycrashed
Honolulu
I would think wires to the starter and to the battery (if it's electric start.)
What do you want from the bike? Brakes, tach?
Kaptain Krunch
Pro Junk Collector
vermont
Pull the whole harness. don't cut anything until you know exactly what u want. If your just simply looking for it to run, start, and charge, you can study the harness and build a smaller simpler standalone harness for the motor. However if your building a buggy i would assume your going to want lights, brake lights, tach, temp light, etc. If you need a fairly complex wiring harness, i suggest installing the stock harness, then cutting, soldering and adapting it to neatly fit your cart frame. Cut wires 1 by 1 and dont cut anything off till the end when your sure you wont need it.
Beautiful- stole the words right outta me. Sound advice!
Swabbster
ok sounds good, i will get it running in the bike first, and once i am in the position to put the motor in i will pull it out of the bike
fowler
Bullsbrook West Aus
U may as well use the dash as well as it has all the info u need
So u are using all the plugs minus a few light ones
It's much easier/safer to leave everything attached and tick the unused plugs away somewhere
I just wired an 04 model GSXR 600 and u would think I have plugs everywhere from stuff I'm not using
Iv got 4 2 pin plugs left
Take everything
A bike in paticular an older bike has nothing but engine components
What sort of cooling have u got
Air alone won't cut it
U will need a large oil cooler
A small car rad is usually used
Swabbster
i talked to my shop teacher, hey said 50 000 is high, is he right? should i still buy it, for a new top end it is about 250-300, so im not sure, reminder i have not bought the bike yet
r97
Measure twice cut once
Massachusetts, USA
What? :confused: Please try to rephrase that in some way we can understand.
souperman000
Westlake Village, CA
:D
He said he asked his shop teacher and his teacher said that 50,000 miles on a motorcycle is high.
He is asking if that is true and if it is still a good idea to buy it because a new top end is 250-300 bucks.
r97
Massachusetts, USA
Thanks, that is about what I had gathered. I'm just trying to encourage people (Not just Swabbster) to think about what they are writing a little more before posting it. A well written question is easier for the person answering it to understand, making it more likely that the question will get answered, which I would assume is what the person who asked the question wanted. Nothing personal against anyone, take a look at some of my posts from when I was in 6th grade.... :ack2:
Now, back on topic. High millage is a subjective term. In my opinion, 50,000 miles is far from new, but I do not believe a number like that is anything to be afraid of if you understand you may need to do some engine work. 50,000 kilometers is relatively low, but you could still be looking at major engine work.
Quite frankly, millage isn't that important. What you are really interested in is the condition of the engine. A brand new motorcycle could drop a valve and require a total top end rebuild, while an engine with 50,000 miles might still have enough life left for a few years in a buggy. The type of motorcycle also makes a huge difference, a twos stroke motocross bike could need a rebuild at the end of one season, while a sport touring bike would be fine for 25 years.
My advice is that you ignore the odometer when you are looking at the bike, a bike with 100,000 miles could have been rebuilt 1,000 miles ago and be in much better shape than one with 25,000. Do some basic diagnostics, toystory_4wd's "five minute diagnostic" thread has some good info in it. Does the engine turn over? Does it fire with a prime? Does it have compression? Does it have a strong spark? Etc. If it has more than one cylinder, check all of them. Ask the previous owner how or when he got the bike, and what kind of maintenance has been done on it. Try to find proof of all of this, people often stretch the truth a bit to make a sale.
As for this engine in particular... it could certainly work, but it is not ideal. The main issue here is that it is air cooled. You can get around that for the most part, but if you can get your hands on a water cooled (and likely more advanced) engine you should be free of over heating issues. If this engine isn't really what you want, let it go and wait for something better to come along. The longer you look for an engine, the more money you will save up for it, and the more you will know what features you do and don't want in an engine. Also, try not to rely on the displacement of an engine when deciding if it will be powerful enough. A CBR600rr engine could easily out perform a DR650 engine. Don't let power be the only factor, the DR650 has many other advantages (simplicity, low weight, etc), and it may be the better choice, even though it is less powerful.
Swabbster
As for this engine in particular... it could certainly work, but it is not ideal. The main issue here is that it is air cooled. You can get around that for the most part, but if you can get your hands on a water cooled (and likely more advanced) engine you should be free of over heating issues. If this engine isn't really what you want, let it go and wait for something better to come along. The longer you look for an engine, the more money you will save up for it, and the more you will know what features you want. Also, try not to rely on the displacement of an engine when deciding if it will be powerful enough. A CBR600rr engine could easily out perform a DR650 engine. On the other hand, the DR650 has many other advantages (simplicity, low weight, etc), and it may be the better choice,even though it is less powerful.
so i think for the price it sounds like a good deal, i live in a smaller city and i do not have my licence so i am un able to drive long distances to buy something, this is the first bike i have came across in over 6 months, being said i think i will take some tools over, check spark, do a compression test, and see if it will fire from a shot of starting fluid, but the best test i think i can do to see if the top end is in good condition, is read the spark plugs, if the plugs are black and all gummed up indicating a nasty oil burner than the deal is off, i don't think cooling will be that big of an issue, making some good air ducts to blow air across the cooling fins should be sufficient,
r97
Massachusetts, USA
I was in the same boat as you, no license, little money, and a desire to get the project started right away. I almost bought a few bikes just because they were all I could find after more than six months. I eventually decided I was better off waiting for the right engine, rather than trying to use something I didn't want to use. Looking back I know that was the right choice.
Taking tools is a great idea! Try to bring other things too, like a battery, and some carburetor cleaner/gasoline. As for plugs... to do a proper plug reading you have to have the engine running at high speed under load. If you can get the engine working well enough to do that kind of test the engine is probably just fine internally. Just getting it to fire a few times from some carburetor cleaner isn't going to get you much useful information. Also keep in mind that an oily plug doesn't necessarily mean the rings need need to be changed.
Properly designed air ducts work fine... just as long as you are moving fast enough. Check online to see if this bike is known for overheating issues, if it over heats with direct airflow on a light weight vehicle, it has got a slim chance of staying cool in your buggy. As fowler said, you might also want to add an oil cooler.
Swabbster
how would you go by adding an oil cooler, well if the plugs are black and oily, like burnt on oil, i think i will leave it, i can't find anything about over heating, :auto::mad2:
fowler
Bullsbrook West Aus
Look to see if anyone else has done it before
Otherwise u would require a fitting in the sump and one higher up on the engine somewhere
Somewhere under pressure to force the oil though the cooler
Can't say Iv played with an oil cooled engine before
Water is in all ways superior
Rustydog2010
NZ Nutta :|
New Zealand
Except when it mixes with the water!
They usually take the oil feed from before or after the oil filter. A common way is to use a sandwich plate.
Swabbster
this bikem will have a oil filter inside the engine, just a little paper filter slides in a compartment, i dont think a plate like that would work,
FatCat
2 stroke Addict!
Ottawa, IL
For your air cooled issue mount a small fan blowing over the fins. Focus this at the top of the cylinder, exhaust side. Now you have air flowing even while sitting still. This is not a replacement for liquid cooling but it is quite effective. Basically it's like the buggy is moving all the time.
fowler
Bullsbrook West Aus
A small fan?
The biggest thermo fan u can find running as hard as u can make it
I wouldn't bother
U will have an oil cooler with a thermo fan and this buggy won't be able to run slow under load For any extended period of time regardless of a fan
Swabbster
that was an idea, take a electric car cooling fan and mount it in front of the motor, they blow a decent amount of air, plus air scoops i should be fine, going to look at the bike right now, i will keep you guys updated, :auto:
EDIT: and this time i wil take pictures of his off road buggy, the st4 by badland buggy, its not done but looking pretty sweet, i cant wait to start my build, i should be getting a job tomorrow so that will help with the money part! as of now i have 350 bucks saved up, total build cost will be about 1200 bucks, my dad will kick in 600
