getting the best out my engine?!
Solidshot
I have a few ideas in my head but I'm going to wait to get both engines working first, don't want to be running before I walk :) but that's kinda the plan!
Solidshot
So gentlemen i figured i should probably give an update on whats happening. Turns out the engine wasnt siezed, i was talking to my dad about it and he said that if i could pull the cord and the fly wheel turnt it should mean that the pistol wasnt jammed, here what actually happened - One of the links in the chain split or something and the chain came off and wrapped itself around the clutch, which was making the whole thing stiff. It wasnt until yesterday that when i took the chain cover off and had a look i saw what was wrong.
I got a new chain put it on and everything is working fine! Payday friday so a oil replacement is in order! Which brings me to my next question. When i put my foot on the throttle only the back right wheel spins? its almost like the back axle is made up of two different axles.
http://www.youtube.com/watch?v=Xiq7Lv1dNPQ&feature=youtu.be
Heres a video to give you a better idea.
I did pick up the replacement engine today aswell, so im hoping to put that on the kart also, but the replacement engine (RE) still has the governor but i dont think the engine thats on the kart at the moment does? So obviously im going to have to remove the gov. from the RE. Also with the RE i fires up perfectly, even sounds better then the one on the kart, but as soon as i take the choke off, the engine cuts out, any ideas why? i tried opening the throttle and then take the choke off....but nothing changes, just shuts itself off. So thats the current progress!
Solidshot
From what I can work out its not a dead axle well at least half of it is. I'll try and get a picture for you lot :)
fowler
Bullsbrook West Aus
It would be 1 of 3 configurations
Do u have a shaft welded to the frame and j
Have a wheel and sprocket on the wheel (1wheel drive)
Do u have a solid metal bar that joins both wheels and runs on bearings
( 2 wheel drive live axle)
Or do u have a sprocket on a cylender and a shaft coming out of each end of the cylender going to each wheel
2 wheel drive with diff
If u have a live axle (Likely) and one wheel isnt spinning then u may have lost/broken a key in the hub
Solidshot
I've just gone out to check, can't get a picture it's pouring down with rain at the moment, the axle is fixed to the back left wheel the sprocket is fixed to the axle. The axle is held in under the kart by axle holder I guess you'd call them. The axle is live right up until the back right wheel the axle spins but the wheel doesn't spin a whole lot. Just spins as if I just spun it with my hand. Does that explain why when I had it out riding, when ever I put my foot down the *** end of the kart swerved out to the back right?
Solidshot
Right so just got a rbeak in the rain and went to take some pictures here they are! A couple of the axle and the things that hold the axle in place, also the two wheels to show the difference between the wheel that turns with the axle and the one that doesnt.
http://i1059.photobucket.com/albums/t423/Solidshot/IMG_0612_zps205e58c6.jpg < Thats the axle holder for the back left wheel.
http://i1059.photobucket.com/albums/t423/Solidshot/IMG_0611_zps7693a986.jpg < Thats the back left wheel.
http://i1059.photobucket.com/albums/t423/Solidshot/IMG_0610_zps297f31e9.jpg < Thats the back right wheel.
Like i say the axle is live through both axle holders up until the right wheel!
This looks like the same setup I have on my daughters kart; it's a live axle set up like a dead axle. ie: The left wheel is keyed to the axle but the right wheel only has bearings, the same as a dead axle.
Solidshot
How do I get the right wheel fixed the the kart? Will it give me any advantages with driving? Also could it be the reason the back end kicks out when I put my foot down?
Solidshot
So todays undate -
I took the back right wheel off, took the hub off make sure it was greased okay, but it back on but when i put it back on i made sure that the nut holding it in was in tightly! Put the wheel back on, started it up, no trouble at all! Turning the wheel by hand now does seem slight (and only very slightly) more stiff then before but not much trouble.
Tomorrows plan, get the replacement engine out, remove the gov. and generally service it. Going to remove and clean the carb properly this time and see what happens from there, i may put that on the kart for now, as im realising a twin engine go kart might not be as possible! :(
Are there bearings in the hub? If so, the wheel would be a bit stiffer because there is more side load on the bearings.
Did you snap any pics of the wheel or axle while it was off?
Solidshot
I think there is, it appears that one set of bearings stayed on the axle when I took the hub off and the other two stayed in the hub. I did get a few pics but I'm on my phone ATM. When I get home ill upload the pictures.
So today I removed the linkages from the governor arm to the throttle arm and made a linkage to go from the throttle arm to the butterfly on the carb. Fired some carb cleaner in to the carb and re assembled everything.
When I started the engine, I was able to take the choke off and the engine didn't cut out! When I pulled on the throttle arm there was a small one or two second lag and then there was a sudden burst of revs and then the engine cut out, same thing happens everytime I rev the engine and the choke is off.
According to my old man the carb jet needs cleaning or something, so my plan tomorrow is to take the small jet out try and get the jet sleeve out also and give them both a good clean, anything else I should be doing?
Last time I cleaned out the small bowl on the carb and the small jet screw.
Johnnym
Oak Harbor, WA
i think most of the practical things have already been said but just to reiterate you can increse flow with a bigger carb and bigger exhaust but by doing that youll have to add more fuel by rejeting to maintain the optimum fuel air mixture. Removing the govenor dosent increase performance too much because that engine reaches peak performance around 3600rpm so by removing the govenor you gain a little hp and rpm but also increased wear. You could shave the head to increase compression but thats only a small increase. In the end power costs money and your only gonna get so much from an engine also there is gonna be a point where it would be cheaper just to get a bigger engine. Hf sells a 6.5 hp for 100 bucks plus shiping and craiglist normaly has horizontal shaft engines under 100. Good luck with whatever you decide to do.
We've had this dicussion previously &, if you look at the power curve, the torque output starts to drop around 2500rpm but, at 3600rpm, the power output is still climbing.
These engines are designed to run all day @ a constant 3600rpm, running above that occasionally will eventually do damage but it'll take a few years.
Have a read of some of the governor stickies
What? So, you're saying a predator (or any other hnda clone) campares to a genuine honda?
Have you read the whole thread? This is not about how expensive the exercise is, it's about gaining knowledge & experience. At any rate, it's better to fix a geuine honda than buy a clone
Johnnym
Oak Harbor, WA
yea sorry about that i just figured out there was 4 pages "duh" i learned my lesson lol. I agree with you that after 3600rpm the power is still climbing just at a cost. I would never compare the quality of a honda to a clone. honda as far as im concered is top of the line. I would rather fix a 10 year old honda than buy a clone however in the begining of the thread he mentioned he didnt have money to buy a new honda i was saying for the price a clone isint horrible but defintely not a honda also ive seen hondas on craiglist for 100 which would be cheaper than modifying a 140 to get more hp. But your right if i had read the whole thread i wouldnt have said what i did sorry about that. still getting the hang of it here.
souperman000
Westlake Village, CA
Don't worry about it, just make sure you read everything first.
Welcome to the forum if I haven't said it already :thumbsup:
