200cc lifan 5 speed engine
16hp... Nice!!!
As long as you guys have the tools and abilities to install it (which could end up being quite involved), then it'll make for a peppy little beastie! Lifan is apparently rather high quality for a Chinese manufacturer. Many of their models are modelled after popular japanese motorcycle engines. There is a 250 V-Twin that is supposedly part-for-part with my Yamaha XV250.
techm80
cape cod MA
on a scale from 1-10, how hard do you think it would be to install i have a welder and plenty of metal
What does your fabrication experience look like? At the very least, you'll have to fabricate mounting brackets, a clutch and linkage, shifter and linkage. Depending on the layout of the rear of the kart, you may have to pretty much chop it apart and redo it complete. Got a pic or two of the kart?
techm80
cape cod MA
and my fab skills are alright! his skills suck!! aha, but do you think an ungoverned 8hp tecumseh with a torque converter would be just as fast??
Umm, no. The 8hp Tec may have similar torque but, once you hit max RPM, that's it. The lifan revs a lot higher &, when it maxes out, it has multiple gears, which also means you can gear it higher, still have plenty of torque & a higher top speed
AMMFAB
Phoenix, AZ
funny that was one of the engines i was looking at on ebay last night.... the only draw back i see is there is no reverse. but if the kart is light enough it shouldnt be a problem to pick it up and turn it around. plus u have manual shifting...... that makes even more fun IMO.
mike
I've been looking at this engine too, what would be the theoretical speed if a 6:1 ratio in fiftht gear?
http://www.diygokarts.com/speed-calculator.html
Do the math :)
mike
Most (if not all) ATV engines have reverse...
AMMFAB
Phoenix, AZ
yes sir i realize that.....that engine is classified as a motorcylce/atv/dirt bike engine and it does not have reverse.......
mike
techm80
cape cod MA
ya, reverse would be great! but w.e i can deal without. now theres a guy on craigslist that is selling a 16hpvtwin and a torque converter for 200 bucks!!!! all together
