Motorized Scooter Build w/ 6.0HP Tecumseh
Ok, so you found a wheel, great. Throw up a pic so I can see what type of sprocket you have & sort out what you can do with it.
One things for sure, you wont be able to use the sprocket coz bicycle chain won't be strong enough.
Bobby
Burlington, NJ
sorry i havent posted anything recently.
ok so i put the wheel on (sorry i forgot to count the teeth on the tire) and tried to take a ride on it but that didnt work too well because the rim is completely bent
Use a spoke tool to "unbuckle" or straighten rim.
On a tire that size should take just a couple minutes.
:iagree: Shoulsn't take long at all. I'll dumb it right down for you:
You'll notice that the spokes from the centre hub to the rim meet in a straight line on the rim but go to either side of the hub. What you need to do is determine what spokes need to be loosened or tightened to move the rim & remove the buckle; if the rim buckles to the left, find the centre of the buckle & loosen the spokes that go to the left side of the hub & tighten the spokes that go to the right side.
Seriously, it's not that difficult. The hardest part is getting the spoke caps to actually turn. Removing the tyre will help in two ways; 1. it removes a bit of pressure from the rim & 2. it exposes the end of the caps which have a flathead slot in them.
Have a go at it & see how you go. Once you remove the tyre, mount the wheel back on the scooter & your brakes will act as a guide...
Bobby
Burlington, NJ
ok thanks guys i think i'll just buy a new tire. 1) because it will already be straight 2)because it will be clean.LOL
sexyvicta
have a go at it & see how you go. Once you remove the tyre, mount the wheel back on the scooter & your brakes will act as a guide
there are no brakes to use as a guide and clearly this rim is quite bent/buckled, i don't think you will be able to true it very well by adjusting the spokes. go find another one it will cost nothing or use the front wheel off the bike. That peddle brake hub will have more drag than a regular hub aswel
