Mini bike help please
zumorikato
Hi I want to build a miÑi bike and was wondering if a honda gx35 engine would do the job? Thank you.
zumorikato
Well it is going to be a mini bike but for an adult speed doesn't have to be high just for cruising around. Any tips?
A GX35 is a small engine. If you are making a "small" minibike, with a light rider, it might work for you. You will also need to pick your gearing very carefully. For those of you who don't know what a GX35 is, here is a pic
roadkill
hi i just got a pocket bike i think it is a x8 but i am not shoure can aby one help
augidog
roadkill said:
You already have a thread on this subject. If anyone has info about it they will reply to it. Please don't risk offending the OP by hijacking others threads
and also you risk offending folks who try to help you in your original thread :toetap05:
zumo'...the (4-stroke) honda & robin-subaru 35's are popular on motorized bicycles, and either can propel an adult at about 25-28mph depending on conditions. if your project's not gonna be a pedal-assist, however, i think you'll be disappointed...neither will have enough power for an un-assisted takeoff unless geared way low, and then you'll see maybe 10mph top-end.
not to mention a drastically reduced life-span. but i did mention it, din't i?
$2 40's & classic rock go together sooo good :cheers2:
Industrial: No less than 120cc
Small motorcycle: At least 80cc.
Each of those will get you around 4 - 6hp. 5hp B&S are very popular, mainly because they're so cheap.
Edit: Come to think of it, a 99cc predator may do the job
