Carb Sizing?
CrashTestDummy
What's the voodoo to choosing the right size carb for a given engine? Car c arbs are measured in CFM, but I don't really see a lot of small engine carbs showing CFM. Example- have a Keihin carb from an old Hoda xr100 bike engine. Could this carb be useful for a 6.5 chonda? I kinda undersatnd jetting, but how big should the carb be to begin with? BTW- the keihin is like a mikuni vm series, but used on hondas.,
Thanks in advance. James.
CrashTestDummy
Fair enough. But- how do you figure it out mathematically? What If I wanted to use that carb on a 2-stroke? I have a 140cc 2-stroke snowblower engine- A 2-stroke inhales on every crank rotation, but a 4-stroke does it every2nd turn. So how do I determine this?
r_chez_08
Should be in the shop...
Cornwall, UK
No idea, sorry. However, a larger carb is not always better- smaller carbs can increase velocity therefore bottom end torque.
I don't think the every other stroke should make a lot of odds though- it would still need to flow the same amount of air, no?
CrashTestDummy
oh. I thought that a 2-stroke of the same size would need 2x the air flow of a 4 stroke because it intakes twice as often as a 4-stroke at the same rpm?
I would've thought the same thing. Unfortunately, my carb theory is weaker than it should be. Still learning.
What I DO know- CFM=CIDxRPM/3456. From thecarburetorshop.com:
"The constant 3456 is more easily understood, and much more easily remembered if it is re-written (12 x 12 x 12 x 2). Note that the dimensions on the left side of the equation are in cubic FEET, and the dimensions on the right side of the equation are in cubic INCHES. As there are 12 inches in a foot, and we must then multiply 12 by 12 by 12 to keep the dimensions the same. The “2” is required because of the 4-stroke engine only drawing air on ever other revolution of the engine. The equation assumes 100 percent volumetric efficiency of the engine (more on this later)."
Having read the above, I would assume the 3456 should be 1728 for a two-stroke, because of the multiplier "2." I would think that you'd drop the "2" when calculating for a two-stroke because it intakes on every rotation.
While this doesn't really answer your question, it might help if you can find an equivalent for 4-stroke and recalculate.
r_chez_08
Cornwall, UK
Maybe 2 stroke carbs are generally larger for the same displacement because 2 strokes generally rev higher, and therefore require greater air flow rate (as the piston is moving down faster)
Just an idea?
No difference between 2 and 4 cycle carbs.
As long as venturi sizes are the same, carbs are completely interchangeable.
Interesting. Would you mind expanding on this a bit? Such as how one might determine an appropriate venturi size, and why a 2 stroke may NOT need more CFM per RPM than an equally sized 4 stroke? How did you determine the correct sizing for your LB projects?
I found the following tidbits which may prove helpful-
http://www.rcuniverse.com/forum/m_839599/anchors_3671949/mpage_1/key_/anchor/tm.htm#3671949
In this thread, there is a formula for determining carb venturi size for a 2 stroke, and it references a book- "The Two-Stroke Tuner's Handbook" by Gordon Jennings. I found the book here- http://www.vintagesleds.com/library/manuals/misc/Two-stroke Tuner's Handbook.pdf
Naturally, I downloaded it. Looks like a very handy thing to have. Hope it helps!
CrashTestDummy
Thanx for the info guys! Hopefully by the time I get through it all I can figure out if this carb is gonna be useful to me for something. I got it off a freind and since its like a mikuni I figure its gotta be worthwile.
