HF Predator engine throttle setup ????
tx7750680
I justy bought a go kart with a 5.5 HP Tecumseh engine. I have a brabd new HF 6.5 HP Predator engine i want to swap in. Can someone tell me how to hook up the throttle cable? The throttle leaver moves with a lot of force and I dont thing it will return after the gas pedal is released.
Any help would be great
Thanks
Blazkowiez
Kart Aficionado
Houston, Texas
Please add an additional return spring just like people need to do on all Honda and Honda Copy engines. The smaller spring on the control arm is not strong enough.
gvfc2
wishing i was living
Tacoma,wa
just to clarify what do you mean the smaller spring on the control arm is not enough?
scarletvw
Minnesota
On my engine I loosened the nut, clamped the throttle sleave to the mount and then the cable to the set screw holding deal. I also put a extra spring hooked to the muffler shroud for a return spring because even with the nut loosened it still didn't want to return all the way.
tx7750680
I loosened the 10mm nut and added a spring from Home Depot. I drilled a small hole in the engine fin to attach the spring. Seems to return ok. ill see if it works on the go kart soon.
tx7750680
It has a spring for sure back by the engine area of the frame. Not sure about the.pedal area. Ill check when i get home. It has a throttle cable.
How fast do you think the kart will go with that 6.5 predator on there?
tx7750680
Also, do you know where i can get a owners manual or parts manual for it? I know that manco manuals are all over the internet but everyone i have asked says this is a thunder kart. Any help would be great
spyder1968
New Bedford, MA
@ tx7750680 you can remove the nut ( in your first pic--has a red dot on it) and the linkage......and under the linkage there will probably be a rubber washer. remove the washer. you can either put in a teflon or hard plastic washer in its place or just leave it out all together. then re assemble and tighten just enough to take most of the slop out of it. this will usually make the linkage much looser. a lot of these motors have this rubber washer because they were designed to be installed on machinery....(log splitters, pressure washers etc) and on said machinery you would simply adjust the throttle where you want it and it SHOULD stay there. obviously not a good idea on go karts ! LOL !
