Honda clone questions
Swabbster
I want to make my Baja warrior have more speed and torque, I have a tav2 on it but I still want more, I was thinking .90 main jet, billet rod, ported gx160 head, ungovorned, and header with muffler, and if I buy a billet flywheel then I will buy 18lb valve springs, but then I can't run the headlight, how much hp will it make without the billet flywheel?
exenos
Project Nut
Before you go spend all that money, add up the total cost and see if you can get a dirt bike engine. I think that you would be much happier with a bike engine.
exenos
Project Nut
Ahh, it was just a thought. They aren't cheap around here either, Its sled engines that are dirt cheap here, $80 for a 440 with ~40 hp. Sucks that its much more involved than just dropping a bike engine on.
Just as a rough guess I would say that your making around 11hp with all of those mods you listed.
Swabbster
ya i can find old snowmobiles and pull the engine, but going in a baja warrior ahhhhhhhhhh i don't want to die! i figure the aluminum flywheel would allow it to rev up quicker, better throttle response, a dirt bike engine i would just have to line it up wire it up throw the chain on and do all the little things and im off, i think i will mod the honda clone, i want about 10hp
Flywheels have nothing to do with HP.
Technically, it does. A lightened flywheel will allow the engine to spin faster & easier as it has less load &, as HP = RPM X torque, it would increase HP; albeit, marginally. A balanced flywheel will have the same effect.
r97
Measure twice cut once
Massachusetts, USA
I'm with Russ here. A lightened flywheel will only affect acceleration, if anything. Where weight is placed on the flywheel can also affect acceleration. Both of these factors will affect the moment of inertia of the flywheel. A lightened flywheel will take less time to reach a top speed, but that speed will be the same as the heavier flywheel's top speed. Altering the size and shape of the flywheel could increase usable power, less/smaller cooling fins would require less force to push through the air.
Swabbster, wait for R-chez to chime in he can probably give you a ball park for the power increase with the modifications you mentioned.
B man
Tecumseh FTW!
Oliver springs,Tn
Now it is true a stronger lighter flywheel will allow you to rev it higher. safely. not that it physically effects it. but in unison with the other correct mods. it will allow you to rev higher than the stock with out risk of fly wheel failure.
r_chez_08
Should be in the shop...
Cornwall, UK
Have a look at the major clone part websites- AGK, NR etc. to give you an idea of what parts go together.
You want to start with the fiter and exhaust, along with a governor removal.
What do you want to spend, and what are you aiming for? How 'DIY' are you?
You can DIY port the head, mill the head, bore the carb, make ratio rockers, high lift cams etc.
IMO what I would do for a torquey build-
-Air filter adapter + filter $25
-Free flowing header $free to $30
-Governor removal
-Billet rod $60
-Billet STEEL flywheel (I would get the new style, non certified) $60
-Flat top piston, tight (ish) end gap on the rings ($15)
-rejet (cheap)
-Black Mamba Jr camshaft from isky $50 (appparently really good) http://www.smallenginecams.com/fr_store.cfm
-Get your compression ratio down to around 10-11:1 (click on the excel document) You can adjust comp. ratio with gaskets, pistons and heads. I have a 14cc head if you want it. Needs valves lapping, but nearly new. Or you can modify your 22cc with some emery paper stuck to glass, using a figure of 8 pattern you can shave the head.
-18lb or 26lb springs
Probably missed out something, but that should be a fairly solid build. You can upgrade the valves if you want, or just use exhaust retainers and lash caps on both valves.
Hope that helps, can supply more info if you want. That should give you a solid build, 6k and hopefully near double the stock HP.
Check out Karting.4cycle.com for more info.
Swabbster
well i was thinking im running a tav2 and they say 8hp max but other people say 10 hp fine, i don't want to be tearing up belts, a air filter and adapter would be nice but if i crash the bike i don't want the air filter to get ripped off and suck dirt, i will do a header and muffler, remove Governor, port intake
r_chez_08
Cornwall, UK
To get 8hp all you need to do is get a better filter and exhaust, remove the governor and rejet.
If you keep the stock valve springs the stock rod and flywheel should be fine IMO.
You can get air filters that fit in the stock air box that are better- maybe have a look at these.
