I want to make my Baja warrior have more speed and torque, I have a tav2 on it but I still want more, I was thinking .90 main jet, billet rod, ported gx160 head, ungovorned, and header with muffler, and if I buy a billet flywheel then I will buy 18lb valve springs, but then I can't run the headlight, how much hp will it make without the billet flywheel?
Have a look at the major clone part websites- AGK, NR etc. to give you an idea of what parts go together.
You want to start with the fiter and exhaust, along with a governor removal.
What do you want to spend, and what are you aiming for? How 'DIY' are you?
You can DIY port the head, mill the head, bore the carb, make ratio rockers, high lift cams etc.
IMO what I would do for a torquey build-
-Air filter adapter + filter $25
-Free flowing header $free to $30
-Governor removal
-Billet rod $60
-Billet STEEL flywheel
(I would get the new style, non certified) $60
-Flat top piston, tight (ish) end gap on the rings ($15)
-rejet (cheap)
-Black Mamba Jr camshaft from isky $50 (appparently really good)
http://www.smallenginecams.com/fr_store.cfm
-Get your compression ratio down to around
10-11:1 (click on the excel document) You can adjust comp. ratio with gaskets, pistons and heads. I have a 14cc head if you want it. Needs valves lapping, but nearly new. Or you can modify your 22cc with some emery paper stuck to glass, using a figure of 8 pattern you can shave the head.
-18lb or 26lb springs
Probably missed out something, but that should be a fairly solid build. You can upgrade the valves if you want, or just use exhaust retainers and lash caps on both valves.
Hope that helps, can supply more info if you want. That should give you a solid build, 6k and hopefully near double the stock HP.
Check out Karting.4cycle.com for more info.
