What you are going to have to do is give us the tooth count on the clutch as well as the axle. If you are geared too high, you can either get a smaller cluth tooth count, a large axle sprocket, or use a jackshaft.
Sometimes getting a smaller clutch or larger axle sprocket is just not practical due to ground clearance issues. If this is the case with you, you will have to use the jackshaft again. You don't want to be buying a new clutch every month.
Your ratio has to be at least 6:1 or lower. Post some pics of your setup and we can help you further. We need to know the specifics
Here is how to post pics
http://www.diygokarts.com/vb/showthread.php?t=735
