Lt-f230
The-Kid
harty,On , canada
hello just got a suzuki mode:LT-F230 I'm missing rimes and wheels dose any one know were i can buy rims for front ? i don't have the manual so i don't know wat kind and online i can't find a thing about this LT-F230
suzuki dual rage 230cc 86-87
and if i can't find rims and wheels i might make a off road kart with it it still run's well i don't want to wast it .
:cheers2:
The-Kid
harty,On , canada
yea is a 4 bolt hub wheel i got wheels and all just not the original and thay were drilled from other wheels so it don't work well i got pic on my profile idk if is what you need but check it out
[/IMG]
a pic without the seet lol battery died lol need new front wheels
me about to add anty rush to the frame
machinist@large
West Michigan, 49331
Stanley Tools makes a combination inch/ metric tape measure that is very handy for things like this. It's a 29 footer but at the time it was the same price as a 25. I bought it at Home Depot. The metric side of the blade is calibrated in mm, cm, and meters. Hope this helps.:thumbsup:
jonboy
Owensboro, KY
I am almost positive that is 4/130 bolt pattern. Most of the quadrunner versions were except for ones with the five lug rear. They were 5/160.
brandongeiger2
Valrico Florida
I have had trouble finding the bolt pattern of mine as well but what size front rim do you need? i have all four with cheap tires on them i was planning on replacing them.
The-Kid
harty,On , canada
tomorrow i will measure and take a photo of the measure and all and if you got all tier's and if thay Mach how much ?? and thanks guy's for all the help
jonboy
Owensboro, KY
That is the wrong way to measure the bolt pattern. See the previous post that Anderkart posted,it has the diagrahm on how to measure. Did you see my post on the pattern size or the link I posted?
buddyochoa
Not Senior Yet
Thorn Hill, TN
Generally the different bolt patters available aren't extremely similar. Meaning if you measure 9cm and there is a wheel with 10cm bolt pattern its probably your wheel.
Hey jonboy, It would be easiest to measure with a Caliper like the pics below. There's usually models available for under $10 at hardware stores, or maybe you even know someone that would loan you a pair.
Or, if you just take that spindle nut and hub off, you could get an accurate reading with your tape measure.
The-Kid
harty,On , canada
kk just got new tiers and rimes thanks for the help and now ama install LED light's on my front rack i gotta make a housing and modify my rack now ama post pictures of the updates wen im done
Run through the translator:
Okay- I just got new tires and rims, thanks for the help! Now I'm going to install LED lights on my front rack. I've got to make a housing and modify my rack now. I am going to post pictures of the updates when I'm done.
:sifone:
:sifone:
Sheeesh. I turn off when I have to strain my brain. Thanks for the translation :D :D
