Predator 212.. What is the cylinder?
crazyman
Yorkville Il
Aluminum or cast iron? I have a generator with a trashed cylinder with a 196cc clone. I'd have to change the crank and cover to use a predator, but I am curious if the predator has a cast iron liner. If it doesn't, I'll bore the stock one and put a new piston in it.
r_chez_08
Should be in the shop...
Cornwall, UK
Iron.
Why would you need to change the crank and cover? The predator crank is different in stroke.
Btw fabroman, some engines have an aluminium bore. They usually use different rings and piston, and do not last as long. Examples are the Briggs 'kool bore' motors.
crazyman
Yorkville Il
The generator has a tapered crank, and the cover is also the mount for the generator. I should pull this one apart to check if it's iron.. It seems like it wore out awefully quick. It has almost 60 psi cranking and looks really new.
I got it free because I combined two junk china generators and made one good one. The customer paid me and left me the junk one.
r_chez_08
Cornwall, UK
Please bear in mind that with the compression release you will gr a far lower reading. Slacken off the exhaust rocker until the compression release doesn't act, then try. It takes a lot to kill an iron cylinder, and you can always buy a new clone block for $30 or something from doverpoweronlinestore.com.
You could replace a predator crank with the genny crank. However, you would need a gx200/clone rod and you would be significantly lowering the compression. You could get around the compression issue by installing a thin copper head gasket and either milling the head or sanding it with sandpaper on a glass pane or piece of flat marble.
You would want around 1mm off the head/gasket.
I didn't say there weren't any & I thought that if the was, that would be the case.
The extent of your knowledge never ceases to impress me :thumbsup:
