Please bear in mind that with the compression release you will gr a far lower reading. Slacken off the exhaust rocker until the compression release doesn't act, then try. It takes a lot to kill an iron cylinder, and you can always buy a new clone block for $30 or something from doverpoweronlinestore.com.
You could replace a predator crank with the genny crank. However, you would need a gx200/clone rod and you would be significantly lowering the compression. You could get around the compression issue by installing a thin copper head gasket and either milling the head or sanding it with sandpaper on a glass pane or piece of flat marble.
You would want around 1mm off the head/gasket.
