2or3wheels
At what RPM does a stock briggs flathead float? keep in mind mine is old so im sure theyre weak. Just wondering if i could just rev her up and have the valves floating be a restrictor of sorts.
Depends on engine. I can easily hold my old cast iron flatties wide open with no load and valves don't float.
Haven't tried it with newer aluminum blocks. May try it on 3hp Tecumseh which I have no use for...unless somebody makes me an offer.
I agree 100%!...all I'm saying...is that the less you do it the better!
I agree 100%!
My point is that when some folks ask about removing governor (in total), the immediate response (from some posters) is to get billet this and billet that when it is totally unnecessary for a stock setup. There are 'built in' limiters other than governor.
It might be higher than that. My junky 5hp (gas powered blender prop) held together at almost 2 miles of going down a road by our house WFO and maintaining between 42-47 mph, which now, I'm learning, was up to 4500 rpm. Not a stutter from it- I was just shocked that it went that fast- going down a fairly steep hill is what helped. The only motor (flatty) that I've ever seen fail was a kid's gokart. (Rod through the front of the motor.) Oil looked like black tar and who knows if there was enough of it in there. I think jrTyler's right. These motors are mechanically stronger than their ability to breathe.I hear that a briggs 5 hp flathead floats on the intake side at 4000 rpm to protect the rod. I dont have a tach so I cant say for sure.
Its when the RPM's of the motor are above the RPM rating of the valve spring. The valve opens so quickly at high RPM's and the spring cannot pull it down fast enough and the motor sputters and back fire's and such. Click link to see a indepth view of valve float under the valve cover. Speicly watch the end of the video how they show the valve actually bouncing off the seat!ok, this is gonna sound dumb, but what does it mean when you say "the valve will floadt"?
