dumb stupid horsepower question
ӍДҬӍДҊ⑤⑤
made ya look!!!!
mims
im having trouble figuring out how to calculate horse power.i suck at math and get a f every year.so i need some help calculating horse power.
Thanks alot!!!!
devino246
Official DIYGK Chem Nerd
Lynchburg, VA
it'll depend on what you're measuring.
Mechanical horsepower
hp(I) ≡ 33,000 ft-lbf/min
= 550 ft·lbf/s
= 745.699872 W
Metric horsepower
hp(M) ≡ 75 kgf·m/s
≡ 735.49875 W
Electrical horsepower
hp(E) ≡ 746 W
Sure enough. But to calculate horsepower? For a gas engine? Can it even be done? I wouldn't know where to begin...
...other than on a dynamometer...
ӍДҬӍДҊ⑤⑤
made ya look!!!!
mims
Engine Type \ Air-Cooled, 2-Cycle Stroke 1.25 in. (31.75 mm.)
Displacement 1.9 cu in. (31 cc.)
Clutch Type Centrifugal
Operating RPM 7,000-8,300 rpm
Idle Speed RPM 2,800-3,300 rpm
Ignition Type Electronic
Ignition Switch Toggle Switch
Spark Plug Gap 0.020 in. (0.5 mm.)
Lubrication Fuel/Oil Mixture
Fuel/Oil Ratio 32:1
Carburetor Diaphragm, All-Position
Starter Auto Rewind
Muffler Baffled with Guard
Throttle Manual Spring Return
and what your sayin is that there is no way to calculate horspower?
Devino may have a magic formula up his sleeve, but I am prepared to say "No". Not that I have ever been aware of.
That being said, if you know the brand and approximate year, you should be able to Google a spec sheet.
Weedeater?
Okay- so as I understand things-
The three key variables are peak torque, the RPM at which that occurs, and the HP (at that same peak)? I would think you can probably calculate to find one of those missing factors as long as you know the other two, right?
So for the purpose of this debate- I AM correct in thinking that without a means of measurement (ie dynamometer) there's no chance a calculator's gonna spit out a reliable number for any given engine. No?
EDIT- Come to think of it- I know from reading various engine's HP and Torque curves, they tend not to peak anywhere near the same RPM...
devino246
Lynchburg, VA
Ever seen an engine that says something like "160hp @ 2500rpm"?
160x5252 = 840320/2500 = 336.128.
So an engine producing 336.128 ft.lbs. of torque at 2,500rpm is yielding 160hp.
You need a torque measurement and the RPM at which the measurement was taken to calculate HP.
This is assuming peak torque, right? If that's the case, the result will the the HP @ peak torque RPM, right? (and not peak hp)I know that peak HP tends to occur well above peak torque. Our industrial engines for example, tend to show peak torque around 2500, yet peak HP shows at 3600 (assuming governor). Looking at a typical RPM/torque curve for these engines, the HP graph is still climbing at 3600, indicating the potential peak at a higher RPM still. Thoughts?
devino246
Lynchburg, VA
Sounds like you got it about right.:thumbsup:
ӍДҬӍДҊ⑤⑤;207908 said:
man,i never thought finding out horsepower was sooooooooooooooooooooo complicated,or even imposible...
It's really not that complicated, you just have to apply your self. You'll never do anything useful if you don't learn and embrace learning.
matman55
I dont have a camera!!
Mims FL
i wannted to lead a double life
jk,i just wanted to change my name to the criptic version cause it looked cool to me.
Jake.B
California-USA
Honestly i think Your best bet would be to call the maker and ask. If you have an F in math your better off giving variables and having somone else figure it out or call the maker. I would seriously adress that F, it will help in the longrun.
ӍДҬӍДҊ⑤⑤
made ya look!!!!
mims
im workin on the f,its the only class i have trouble in,i read and comprehend like 5 years before my grade but im still in middle school when it comes to math
Orange Krate
North Texas
To "calulate" horsepower without run/test data requires the use of Calculus on the Otto Cycle. Yeah, it's complicated.
But, there's hope for your math skills. Start with easier calculations (like gearing) and build up from there. The key to understanding math for gearheads like us is making yourself interested in what you are claculating, then testing it in the shop to see how close you came.
I went from dropping math courses to an A in Calculus because a machinist taught me how I could "use" math. That made all the difference.
ӍДҬӍДҊ⑤⑤
made ya look!!!!
mims
im really interested in gearing.do you know what i should start learning first?i assume gearing is gear ratios and all that stuff right?
Orange Krate
North Texas
I haven't forgot about you, just got real busy! I'll try and work up some good and practical math applications specific to go-karts, gearing, etc.
This might make a good "sticky" later...stay tuned!
matman55
Mims FL
Alright!! now its a party
