Engine Type \ Air-Cooled, 2-Cycle Stroke 1.25 in. (31.75 mm.)Sure enough. But to calculate horsepower? For a gas engine? Can it even be done? I wouldn't know where to begin...
...other than on a dynamometer...
Okay- so as I understand things-
The three key variables are peak torque, the RPM at which that occurs, and the HP (at that same peak)? I would think you can probably calculate to find one of those missing factors as long as you know the other two, right?
So for the purpose of this debate- I AM correct in thinking that without a means of measurement (ie dynamometer) there's no chance a calculator's gonna spit out a reliable number for any given engine. No?
EDIT- Come to think of it- I know from reading various engine's HP and Torque curves, they tend not to peak anywhere near the same RPM...
You need a torque measurement and the RPM at which the measurement was taken to calculate HP.
This is assuming peak torque, right? If that's the case, the result will the the HP @ peak torque RPM, right? (and not peak hp)I know that peak HP tends to occur well above peak torque. Our industrial engines for example, tend to show peak torque around 2500, yet peak HP shows at 3600 (assuming governor). Looking at a typical RPM/torque curve for these engines, the HP graph is still climbing at 3600, indicating the potential peak at a higher RPM still. Thoughts?
ӍДҬӍДҊ⑤⑤;207908 said:man,i never thought finding out horsepower was sooooooooooooooooooooo complicated,or even imposible...
I haven't forgot about you, just got real busy! I'll try and work up some good and practical math applications specific to go-karts, gearing, etc.
This might make a good "sticky" later...stay tuned!
